i want to invert my subs. instead of having the motor inside the bax i want it on the outside. i have always been told that when you do this you have to reverse the polarity. is this true?
----reference's----
meade916
No, its not true.
You should only have to change the polarity is if your running say 2 subs normal and 1 inverted, or 1 sub normal and 1 inverted. Then you would change the polarity on the inverted sub, or you will have phase issues with 1 sub canceling out the other.
do both, see which sounds best.
you also need to be as in phase as possible with your fronts
-Drew
uhoh_45 said:
caddy-that would be ok. i built my box a little on the small side so i would not have to rebuild it when i get my new amps. and if i did the math right it would raise my tuning to 41 herts from 38. which is also fine it would help on the mic.
----reference's----
meade916
noobtastic what do you mean by you also need to be as in phase as possible with your fronts.
i thought that as long as you wired the speaker/subwoofers carrectly they would all be in phase.
----reference's----
meade916
its case dependent. In my truck the sound sounds A LOT better and louder the with sub 180 out of phase with the speakers. With the sub in phase the output drops by atleast 4db I have no idea why though.
Indeed. It's all about path lengths and how the wave is phased when it meets the wave from your front speakers. Infinitely adjustable phase is nice but sometimes just a good old 180 phase switch can work wonders.
Generally flipping the phase won't change your burp score on the meter a single bit, but it can have a massive effect on your midbass, as mentioned here.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 4812 Guests (See full list)
