Blazer + Solo X 18's = Fun!
keep em coming bro, that shit looks like its gonna knock stupid hard... those subs were barely moving, and it sound real good. im sorry if i missed it, but whats it tuned to?
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
nice i can't wait to see what the dash is going to look like
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Looks good. Sure is gonna hit hard when you get the right power going to them.
Team DC!
2005 F150 | Pioneer | Infinity Kappa 6x8's | MTX 3404 4 Channel | Q Logic Kicks | KNU | DC | AQ |
1998 Taurus | Alpine | Punch 5x7's | Rockford Fosgate | MTX | KNU |
Its tuned to around 35hz. And as far as the dash im thinking of a black piano finish. Still need to figure out what im gonna do for mids and highs. Im going to be running 2 memphis 16-MCA3004
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
This is a little off topic but how hard was it to access the heater core. I have the same interior as you with the exception of mine being a 5 speed and my core leaks and I have no heat. Did you tear the whole dash apart or just flip it foward like the repair manual says?
TDH FTW !!!
It was not that hard. It just had alot of screws and and bolts you have to remove to remove the dash. But once I got them all out, then I droped the steering colum, then I uncliped the main harness to the dash and a few others and removed the dash and sat out side the car. Then you have 5 or 6 bolts that you have to undo that mounts the heater core assembly. I think 2 are located on the upper fire wall and then you have two that are in side the blower assembly then you have to remover the passenger inner wheel well and you have 2 on the lower part of the fire wall. After that you should be able to pull the heater core assembly of and just slide the old heater core out and put the new one in and reasemble everything you just took apart. It is alot of work! But if you take your time and go step by step you will get it done. Hope that helps.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Ok today I was messing around and decided to throw some batterys in the blazer I had laying in the shop. I wired them up and wanted to see what it would do with the gain up about 3/4. And I was playing some real low stuff and with it droping down to around 12v I was able to geat a really good http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif I will be getting a vid tomorrow for sure.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
well I was gonna get a vid but the ipod died and I dont have another. It just wont play music for some reason I will try it with a different song on a cd but it skips so I might not be able to.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
charge your ipod, it takes like 10 mins
R.I.P!
(Nov-29-2009)
92 explorer
current build
