I have questions about some alternators, so basically i am looking at excessive amperage and iraggi.I can get both for around the same money and they both are 200 amp alternators.
When you say 200 amp alternator, that means 200 amps max, so it is capable of doing 200 amps but after that yuor alternator will be messed up(i dont know how to say it i duno what happens to it)
Alternators arent over rated or anything are they?
I just want to make sure that what i get is what i need, 180 amps seems definetly enough for my system. I am not sure how much my cars electrical components will need, someone said around 10-30 amps i duno.
Baylor University
Accounting
first off what amps(s) and how many watts are they? next a 200amp wont give out anymore than 200 amps.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
okay so what about excessive amperage?
They said the max is 200 amp alt with direct bolt on,
does direct bolt on mean just keeping the alternator int eh same place and bolting it to the same place the stcok alt was bolted to.
Baylor University
Accounting
They actually vary quite a bit.
I've seen Iraggi offers some that are different series like Amputator vs Doominator series and they my both be 200amp but one does 75amp @ idle and the other does 175amp @ idle.
I would assume the 175amp @ idle would be either MUCH tighter wound or just involve a different VOLTAGE REGULATOR (be it internal or external).
If you have Q's on it and want some professional help, email Dom Iraggi. I'm sure he could let ya know the ins and outs and recommend the bst scenario based on tonns of experience.
I am saving up for an Iraggi unit myself.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
excessive amperage said the most i can get with direct bolt on is 200 amps, i am just going to get it and a new bettery and big three upgraded and hopefully it will work
Baylor University
Accounting
Well right now i got T302 with P2's but i am going to go with maybe 2 T1's, definetly 1, so depending on if i go with two or not is between the T1001bd amp or the T500-1bd amp .
then i am going to have a T400-4 amp for speakers and tweeters
and i am going to probably use the T3002 for 1 sub and some speakers also
The sad thing is, ia hve the money, i ahve been saving up, but i dont got the time.
OFcourse with teh new alt will come the big three and a new battery
Baylor University
Accounting
