Guest KyleCannon Posted January 6, 2009 Report Posted January 6, 2009 If I ran a T1500 at 1 ohm with a BL, would that be too much for it or is it underrated like the BTL as well? Does anyone have a BL and pushing around 1800 watts to it? I am thinking about getting two of them and getting a second T1500 and running one amp per sub. Quote
gotFI? Posted January 6, 2009 Report Posted January 6, 2009 that amp would be perfect for a BL. ran my old BL 18" with a rf t10001bd at 1 ohm. the BL was sleepin! Quote
Guest KyleCannon Posted January 6, 2009 Report Posted January 6, 2009 Alright, that's what I like to hear! Time to save up! WOOT! Quote
Guest KyleCannon Posted January 6, 2009 Report Posted January 6, 2009 Is it going to be a problem because I can't sync the two amps together non like the Power Fan Cooled Series? Quote
Nightshade Posted January 6, 2009 Report Posted January 6, 2009 Is it going to be a problem because I can't sync the two amps together non like the Power Fan Cooled Series? It won't be a problem if you gain match the outputs of each amp to the same. All you need to do to do that is unhook the speaker wires to both amps and play a 50hz tone. Set your dmm to ac voltage and probe the positive and negative leads. Adjust the output voltage of each to the same and your set. The only way to get a clean signal is to set it with an o scope, but those are hard to come by so you will have to use your best judgement on setting the gains without a clipped signal. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
gotFI? Posted January 6, 2009 Report Posted January 6, 2009 It won't be a problem if you gain match the outputs of each amp to the same. All you need to do to do that is unhook the speaker wires to both amps and play a 50hz tone. Set your dmm to ac voltage and probe the positive and negative leads. Adjust the output voltage of each to the same and your set. The only way to get a clean signal is to set it with an o scope, but those are hard to come by so you will have to use your best judgement on setting the gains without a clipped signal. ^^^or just full tilt the gain! Quote
Boon Posted January 7, 2009 Report Posted January 7, 2009 ^^^or just full tilt the gain! I really really hope you're not serious... Quote 10.x volts fo' life!
Derrick824 Posted January 7, 2009 Report Posted January 7, 2009 That kinda power is perfect for a Bl. Quote
E a r t h Posted January 8, 2009 Report Posted January 8, 2009 If my Q can handle that power, you should be fine Quote
Guest KyleCannon Posted January 8, 2009 Report Posted January 8, 2009 Got a TPI 440. Won't be that hard, thanks for the responses, have to get the financial situation under control and probably at that time, I will be getting the RF '09 amps when they are released Quote
