Ok guys. If my sale for my 1500d doesnt go through so I can get my 3000d Im considering just buying another 1500d and running each one per sub at .5ohms. Iv heard of people getting them down to .5 daily with no problems. I will be using this daily. Does any one have any input?
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
I don't think sundown will warranty down to .5 ohms. I know with the 3000D you dont gain alot more power, but you do lose efficiency, so I think it would be a likely scenario with the 1500D as well.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
Not realy concerned with the warranty as itl probably be a used one. Iv got a good eye for my equipment though so I wont let any thing happen to it. Just curious to know how hot they get how quick.
I beat the piss out of mine at times and they don't get hot at all. I have a stock 800 cca batt up front and a Powermaster D3100 in the rear of the car so voltage isn't the worst. On music I haven't dropped below high 11's, and on a burp I only drop to a 12.4 at most. I do have reason to believe that the 1500's do make about 500 or a bit more watts at .5 over 1 ohm wiring. This is because after rise you still have the amp at a lower impedence than if you were to wire it at 1 ohm. In my case I wire each 1500D at .5 ohms and when rise is calculated it's at 1.45 ohms. Now if I were to wire at 1 ohm it would probably be closer to 3.5 ohms after rise. Therefore the lower impedence actually creates more power after the reactive load is determined. Even though the amp is wired at .5 ohms the chances of it ever actually playing at .5 are very slim to none. Just be careful of the waranty, but it's not all that expensive to fix if you do burn up the power supply. What's the electrical look like in your ride Zade?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Get a few electrical upgrades and watch your gain settings & volume control. A 1500d @ 0.5 will put out around 2kwatts on good electrical. Bl's do well off 2kwatts but that's a lot of power for them so you have to keep an eye out. Set everything up correctly and you'll be plenty happy with the end result.
Thanks for the replies guys. I have done the big three I have a 200amp alt and have a 875caa battery up front right now. I plan on getting one realy good battery up front though. As of right now my single 1500d is very happy with electrical but I know Il need another batt to run 2 1500s. Would strapping hem and running them at 1 ohm be a bad idea.
bumping
Why not go to the SunDown Section and read or go to *** Forum you will get all the answers you need. There is plenty of feed back with people running the SAZ line @ .5...
Team Ampere Audio
efficiency sucks!! biggest thing i noticed bringing my hifonics form 1ohm to .5ohm was how it became a power hog- keep your electrical up to par and keep the signal clean and you should be in good shape
-Drew
uhoh_45 said:
