BTW, what I just wrote is why I think its so funny that people put box tuning in there sigs and specs. Like 2.5 cubes tuned to 33 hz, lol
What if you put in different subs, what if you add power, what if its cold, what if its hot, what if you put your AC on, what if its raining, what if you put the box in a different car?
What your box is tuned to isnt really an important spec. Mine is tuned to 20-80hz.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
very nice info ed very nice.
so in order to really tune a box u need to be able to accurately measure the airspace, density, and relative length of the vehicle it is in? hmm this is a fun subject.
so wut about resonance? why is it that the most common boxes utilize the sound bouncing around aimlessly in the box instead of simply directly the rear wave forward through a tube sorta thing. is there any real benefits to a standard ported box vs say tlines other than relative size?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
The sound isn't 'bouncing' around inside the box - it's a wave so all it's made up of is differing areas of pressure.
The reason we curve corners etc is to try and prevent spots of high pressure. The waves collide in the corners and will interfere with each other - be it constructive or destructive interference. Sometimes we want to create areas of generally higher pressure, particularly around the port mouth.
A ported box generally provides more cone control and power handling than a t-line or horn - although the 'exotic' designs are far more efficient to a point, they are limited because the sub is running virtually free air (hence why they're so efficient) but will quickly get into the realms of over-excursion unless it's an incredibly stiff driver or very restrictive port/mouth. This is why in extremely high power systems the box is usually ported, sealed or a bandpass box - these offer much more mechanical control (and hence protection to the driver) and when power is virtually unlimited (such as in an Extreme vehicle) the ability to control the woofer is more important than a slightly higher efficiency.
This is just my understanding of it :)
10.x volts fo' life!
good info boon
now think wit me is it possible to create back pressure in a t-line for cone control and power handling while still being much more efficient?
it involves wave compression and a quarter wave length in a funnel type enclosure... i dont like it tho cuz the port mouth on one design came out to be less that an inch in diameter for an 18" woofer.... seems wrong to me
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
good info boon
Im thinking you may be interested in seeing Forevrbumpn's tline bandpass box? (tline with a sealed airspace on the outside of the cone if you get what im saying)
linky?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 2876 Guests (See full list)
