by the way there should be a black wire that you dont touch take the bypass mod pink/white connect it to the pink yellow or white away from the cylinder take pink with black from the bypass mod and connect that to the pink yellow or white wire towards the cylinder so you have to cut the pink yellow or whit wire
That is kind of what i was getting, wanted to ask before i went cutting, and the yellow wire at the cylinder is the only wire i use, so sounds right
THANKS
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
ok sorry bro without have the truck in front of my face and the mod itself is kinda hard but i was getting there lol hope it works for you bro
must be nice huh
Did you get this working? are you useing a 555L? 1700G?
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
I am using the DLPKGM or trying to. dei says it will work for passlock and pass key. not using the doorlocks or anything on it just for bypass. i know i should have got the 555l but directed site says it will work. Just need to know what is up with the OBD2 wire, and if the status output wire from the alarm goes to the blue/white wire on the bypass. Do i have to cut the yellow vats wire. hook it up to the input on the bypass and then the bypass to the other cut side of the vats wire
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
Connect the purple wire from your DLPKGM to the OBD2 wire... purple wire in your obd connector at bottom of dash, pin2. solder this wire.
connect the violet/white wire from the DLPKGM to the purple/white tach wire on your remote start
blue/white from the DLPKGM to the status output from your remote start... blue or blue white.
ping from the DLPKGM to your pink ignition wire
and that should be all the wires you need for remote start off the DLPKGM... we just started using them instead of 555Ls at work.
you do not need to cut your passlock wires with this bypass.
Edited by Shyne151
Kenwood eXcelon 995
tahnk you very much.
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
[/qu
Got it hooked up but it tries to start then shuts down, what all wires have to be hooked up on that bypass
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
Finally got everything working it starts, but brake shutdown does not work, tach shutdown works, hood pin works but brake dont, and also when i put the key in and turn the back and take it out the truck does not shut off
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
Now the only problem is the brake shutdown, i have it hooked up to the white wire on the switch above the brake pedal, the wire does not read 12v when depressed. Is there another wire that will read 12v when pedal is pressed
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
