Half way through instal everything fine, sensor and door triggers working fine. After hooking up doorlocks, almost everything stop working. Alarm will sound if holding down lock, and doorlocks work just fine. It doesnot chirp when i arm it, and door triggers, shock sensor dont seem to be working. Anybody got input
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
I am about 1/2 way through installing a 5900 on my PT, will finish it up tomorrow.
Are you using an adapter kit (Xpress kit or Omega), or are you wiring it direct? Reason I ask is sometimes if you confuse the adapter while it is programing itself, it will not work and you gotta disconnect it and start over.
Also, I think if you are direct wiring it, there is polarity for the locks, (positive or negattive) any chance you might have a wiring issue where the locks are connected to the alarm brain?
I am far from an expert. Hopefully Shyne will be able to post and help you out.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
its in valet mode
open the door then on the keypad hit lock unlock lock.
then you should be set
NoFearX18 said:
trainman0978 said:
^^^or key on then off and then press and release valet button
i thought that was to bypass the alarm all together for say if your remote isnt responding to the vehicle or if you lose or break the remote.
NoFearX18 said:
trainman0978 said:
yes it was in valet mode, what can i say, im a noob
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
You are not alone!!!
I am a few wires short of finishing up mine, taking a food break!
....then I'll be posting up similar questions! :drinks:
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
chodemang solves another one hahahaha :D :8)
NoFearX18 said:
trainman0978 said:
