Cant figure out where the white/blue remote start activation wire goes to from the primary harness. the instructions say nothing
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
Tricky, what I found from direct wholesale is this "This vehicle has 2 door trigger wires, the DRIVERS DOOR is a TAN (-) PURPLE plug, B4 and ALL OTHER doors BLUE/WHITE (-) LIGHT BLUE plug, Pin B11 at the BCM use both wires and DIODE ISOLATE when connecting to an ALARM SYSTEM" along with this diagram:
http://64.85.6.129/extrainfo/diagrams/2650...N%20CIRCUIT.pdf
any other information can be found http://www.directwholesale.net/diagrams/diagrams.asp?link=DW. Good luck and good choice on alarm!
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
I have the whole alrm installed everything works ecept the reomte start is not fully hooked up/ i need to know wher the remote start activation wire goes to start the remote start white/blue wire
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
white/blue on the main harness is remote start activation input... it is used for an external source to activate the remote starter. You don't need it.
Edited by Shyne151
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
Does it hook up to the bypass kit
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
sorry just seen u said dont need it thanks
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
Nope, but blue off the 7pin remote start harness does.
Kenwood eXcelon 995
The blue/white status output goes to bypass
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
Same thing as the blue wire off the 7pin... except on some viper models the blue/white can be programmed to pulse and a few other things.
Kenwood eXcelon 995
and whats up with the data OBD2 wire, sorry new to remote starts using the DLPKGM bypass kit
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
