Boon Posted January 14, 2009 Report Posted January 14, 2009 Right. Im about to put together my proper battery bank. It consists of 12 batteries the same size as a Kinetic HC600. Each battery will be connected with a short piece of 4ga to a large bus bar. The question is, do I bother fusing these short runs of wire between the bus bar and batteries? I can't really see them ever shorting out but with $15k of gear going in I don't really want any fires in the trunk... Otherwise there will be 2 runs of 0ga going from the bus bar to an NSB90 under the hood. These will be fused at both ends with 250A ANL fuses. What's your thoughts on fusing battery banks? 10.x volts fo' life!
n8ball2013 Posted January 14, 2009 Report Posted January 14, 2009 now you know you are supposed to fuse them. How stable are they going to be. what are the odds of them ever coming loose. how well are you going to maintain them. etc etc. If you can be assured that nothing will ever come loose or be moved like in a vehicle accident then i wouldnt fuse them Flame away THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
kbreudi Posted January 14, 2009 Report Posted January 14, 2009 Fuses are for pussies!!! Team No Fuses baby!! TEAM SUNDOWN 4 Nightshade 15"s 2 Sundown SAZ-4500 8 Deep Cycle batts 1998 Cadillac Catera SPLMAX CUP 2008 Fourth Place Overall
uhoh_45 Posted January 14, 2009 Report Posted January 14, 2009 is there anyway to not use the wire and just use straight bussbar on the batts R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Bills Posted January 14, 2009 Report Posted January 14, 2009 i'm in the same boat, i may not be fusing. but its just somting safe. so if you have the money to do fusing and your wanting to do a nice looking instal. i think a ton of fuse terminals make it look nice. but thats me. Bills KwB Team DC Audio Midwest captain
reinke Posted January 14, 2009 Report Posted January 14, 2009 Fuses are for pussies!!! Team No Fuses baby!! iirc you have fuses. ----reference's---- meade916
Boon Posted January 15, 2009 Author Report Posted January 15, 2009 is there anyway to not use the wire and just use straight bussbar on the batts No unfortunately - the install is going in a really cramped space, the theme of the install is how much gear I can fit in a very small car. The batts won't be going anywhere, they'll be almost totally enclosed. I think I'll go with no fuses, I don't see them ever shorting... Cheers for the input people 10.x volts fo' life!
RamenNoodles Posted January 16, 2009 Report Posted January 16, 2009 Good choice, more tedious work FTL Diablo Audio Technologies Fi Car Audio Ascendant Audio
