I have a 1997 chevrolet S10 that has a vortec v8 5.7 and i would like to lower it and do a body kit? I would like to go as low as i can without any problems. What would you sugguest doing? I heard you could just cut the front springs and flip over the leaf springs? any ideas?
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Front could do drop spindles and lowering springs and the rear you could do blocks or leafs and blocks. If you want to go lower then say 5" you should do bags front and rear. Dont really need a notch in the rear unless you wanna lay body or frame. How hard was the 5.7 swap and what was the engine out of? Thanks
Edited by LoudBlazer
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
The 5.7 swap was crazy my father put a vette motor in his tahoe and gave me the 5.7 Dont ask about the install cause i didnt even bother to install it.
Now the the crazy michigan roads with potholes and such i dont want laying frame i only want 3-4 inches of drop. Know any kits or websites?
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Depends on you wheel and tires on how low you can go without problems.
4-5 is the lowest I would go without bags, but you will need a lower profile tire cause the front wheel stock will rub like crazy
Team Ampere Audio
how much money would you like to spend? Did the v8 swap not lower it a bit in the front? You can buy drop spindles for the front, several companies make them,, id reccomend Belltech or DJM over any others. Cutting the springs is a cheap way to do about it, but if you do, cut them with a bandsaw, a torch will heat up the entire spring and drastically change the spring rates,, in other words itll be extremely soft. Your axle is already over your leafs in the back, so you either need drop blocks, or drop leaf springs. sorry if this doesnt really make sense,, but if you got any questions, pm me and ill be glad to help
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
