If your buying the amp new, I say DD.
American bass has a undisclosed flaw about their amps..
If you let them sit at a idle or turn your sub preamps off or have volume on zero your amp will get hot sometimes kicking protect or just going up in smoke.
Only amps Ive ran so far that ever done this.
Being that they are Zenon built I believe, I wonder if sundowns have this same flaw which is also zenon built??
lol i run a vfl and it has NEVER once EVER even got warm, 3k rms+ way under rated
ab is on top with the VFL's all awesome daily amps and i think he defiantly had a problem in his car lol
1 15" LMS Ultra<-Sold
2 12" Audiopulse Axis Quad Coils
2 18" RD Audio Alpha V2's<--For Sale or Trade
American Bass VFL 700.1 (alot of power at any ohm)
American Bass VFL 200.1 (3.8k rms @ .5 ohm)
2.1 cubes each at 32 Hz
125 sq ft RAAMaudio BXT, 5 Yards Ensolite
50ft 1/0 Knu Flex wire
4 Infinity 6.5"
Temp 170x2@2 ohm Sony amp
200 Amp EA Alt
3 Exide Orbital's
Youtube Vids....http://www.youtube.com/profile?user=gavinriley&view=videos
x2 im runnin ab and never heats up on me and i pound daily
JVC AVX-2
Audiocontrol EQX
(2) 12" Audiopulse Revo
Planed Audio P2250 D @ .5 ohm
All Class D amps get hot in the output section when they idle. I was amazed at how hot a Sundown SAZ-3000D got on my test bench considering it didn't even have a load connected.
My VFL400.1's idle fine. There were a couple of flaws with a certain generation of Zenon amps but I'm pretty sure they have them ironed out now.
All that said, DD. Although the DD is also Zenon AFAIK, haha. Pretty damn sure they use nearly identical output sections.
EDIT: Yup, both have 16 IRFP360LC's in the output section and use the same driver board so you can be pretty sure power output will be very similar.
Z1a uses 6 small power supplies whereas 500.1 uses 4 larger ones, so the Z1a is probably a little more efficient at Street voltages and the VFL will like higher voltages better.
Edited by Boon
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 3422 Guests (See full list)
