OK... co as of now i have 1 D2 BTL 18" on a AQ2200D wired at 1 ohm...I want to add another sub and amp.
So if i add another sub and amp i can either:
-Expensive Method:
Says this on AQ.com: 2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
This means that i can link the 2 amps together and ill have 4400rms at 2 ohms correct? Then i will need to recone my BTL i have now to a D1 and then order another D1 BTL and i can wire it up. I think im correct with this...please correct me if im wrong!
-Cheaper Method:
Buy another AQ2200d and another D2 BTL and wire seperate power wires for the amps and run 1 amp per D2 sub.
My problem here is that 1 is going to cost me much more and the other is going or seems to be alot more difficult tuning wise...
Which should I do? ANY info is GREATLY appreciated!!!!
Thanks in Advanced!,
NoFearX18
My Videos
AQ + AA/Fi FTMFW!!!!!
for tuning on strapped amps you just tune the gain and settings on the master amp and the slave follows w/e you set on the master.
yea but its requires me to have 2 D1 subs correct?
I dont want to have to pay like $200 or more (estimate) to recone my BTL lol... thing weight a ton and a half.
My Videos
i'd just buy a sub/amp, and link em with a maxx link. saves the trouble of reconing. or you could put a divider and run them in separate enclosures and run each amp separately but tuned as close together as possible
if you wanted 1 sub on those two you can have a D2 BTL, but if you want 2 subs i think you would need D1's yea...but i dont know why you would want 2 subs on 2 strapped amps instead of 1 sub on each amp independently
What are you refering to when you say divider?
Doesnt have to be a separate enclosure tho does it? lol
Id prefer to do it this way because all in all its cheaper. i can get the amp and everything and dont have to recone the BTL i have already.
Im just unsure of how easy it will be to tune 2 amps...
Edited by NoFearX18
My Videos
Colton, I would honestly save up and get the woofer reconed so you can run them master/slave. Its a lot easier tuning wise obviously and not to mention, you will only need one bass knob.
OR you could look into a maxxlink.
o shit i didnt even think of the bass knob.... A maxxlink will make it to where i can run 2 D2s on 2 amps? and i wont lose any power or anything?
it may cost about the same to have the sub reconed as it would to buy a maxlink... hmmm.
i need to email Fi
My Videos
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Why can't you listen to James?
2 D2 subwoofers wired series/parallel gives a 2 ohm final load!
Strap 2 AQ 2200's to it and you get 2 ohms total or 1 ohm per amp and everything is fine!
If you recone to D1's you are screwed. Good work everyone that recommended that option.
EDIT: And you don't need a MaxxLink!
When you 'link' amplifiers they see half of the total load each. That's why the ratings are usually @ 2 ohms.
You want a 2 ohm FINAL load so you want D2 subs, you link the amps (so no MaxxLink needed) and you use a common chamber box unless you have some enormous reason to do otherwise.........
Edited by Boon
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 2630 Guests (See full list)
