Need Help! Adding On To My System...
wrong wrong wrong
all you need is another d2 sub and amp to run strapped at 2ohms
NICE!!!!!! thats what i was hoping but i was unsure... i didnt think my logic made much sence.
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Why can't you listen to James?
2 D2 subwoofers wired series/parallel gives a 2 ohm final load!
Strap 2 AQ 2200's to it and you get 2 ohms total or 1 ohm per amp and everything is fine!
If you recone to D1's you are screwed. Good work everyone that recommended that option.
EDIT: And you don't need a MaxxLink!
When you 'link' amplifiers they see half of the total load each. That's why the ratings are usually @ 2 ohms.
You want a 2 ohm FINAL load so you want D2 subs, you link the amps (so no MaxxLink needed) and you use a common chamber box unless you have some enormous reason to do otherwise.........
Sorry i did not see James's post. I do now and it makes much more sence to me now. I had it backwards.
I was wondering why no matter which way i went i couldnt make sence out of it haha.
Thanks James and thanks Boon :)
My Videos
AQ + AA/Fi FTMFW!!!!!
I believe you run the pos to the positive terminal on your master amp and the neg to the positive on the slave amp, correct me if im wrong i also am trying to understand this 2
Team_DC-Derrick's Youtube
Team DC Audio
if you wanted 1 sub on those two you can have a D2 BTL, but if you want 2 subs i think you would need D1's yea...but i dont know why you would want 2 subs on 2 strapped amps instead of 1 sub on each amp independently
wrong wrong wrong
Your subs are fine....jesus if people don't even know ohm loads...do not suggest anything even if your trying to help.....that could have ended up costing him alot of money if sent his sub out to get reconed......
edit: good thing James and Boon came in here lol.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
run the positive to the Master positive, run the negative to the Slave positive, connect the negatives of the Master & Slave together
ok this is starting to make more sence. thanks!
What about the power wire? I can just run an additional wire of the batterie in the rear correct?
My Videos
You're adding more batteries correct? There are several different ways you could go about this, some better than others
How many runs do you have from front to rear?
1 run front to rear....
i have 4 batteries in the back now.
my question was could i just run another wire from the rear batts to the 2nd amp?
My Videos
  • Who's Online   1 Member, 0 Anonymous, 973 Guests (See full list)
