Two Solox 10s And A Ss10000d = 150.6 Good?
daddy_j
That was a good link, and I will use some of that info, but that guy had four 12s. One guy wrote he hit ~158dbs with two 10s. Now that is what I find impressive. 160 with four 12s, isn't that impressive. I find it cooler when someone with a single speaker or two small ones hit crazy numbers. And I don't mean in a SUPER MOD CLASS, I mean in a street driving car, not a trailer car. I love it when I see two 10s hit 155dbs, thats just crazy.
i'd like to see those 2 10s doing a 155 play music, because those are one note wonders in a street car, 2 15s in a small ass car can burp a 154 at 42 hz or something and play music in the 149.9 class, to me thats more impressive
fart box's/pure spl machines arnt fun sure the numbers are good but its not like you can listen to it or anything
R.I.P!
(Nov-29-2009)
92 explorer
current build
I just hooked up the two aero tips to my PVC pipes and it really seems a little louder, but I wont know for sure until Tomorrow. If I win the Comp tomorrow I am going to use the cash for the 2 6" aero port kits. The ones for $37. I have a maxxlink but it doesnt make me gain or lose, right around the same numbers. Right now the ports are the same size that I had on there before the areo tips. Someone says that they may need to be an inch or so smaller, to make up for the flare. I will do some testing tomorrow morning to see how short I have to cut them. And to See if I gain or not by just putting flare tips on my ports. After this comp, I will Be adding 16volt batteries, to see how much more I gain.
I can listen to music in mine, and still hit 148dbs in Streetbeat. I listen to mine all the way home from a comp.
whats your box tuned to?
R.I.P!
(Nov-29-2009)
92 explorer
current build
fair enough, back to helping you get loud your box's in the car can you move them apart or anything like have you really messed with moving the boxes around or anything after
like separating them or anything like that
Posted Image
or putting seats forward or visors down its the stupid shit like that, that gains you a tenth of a DB
R.I.P!
(Nov-29-2009)
92 explorer
current build
That pictures misleading, you don't see whats under there.
Looks like someone built those boxes a lil big to get under window line.
btw that box was tuned at 48hz! PLayed music fine
this is the only other pic i could find
but seeing as how this is your rex im sure theres better pictures
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
How many freakin ports are there on that box? I have played with moving the boxes and where they should sit, and thats where they sounded the loudest. I haven't resined the box or put any 45s. That will be my next step along with adding 6" aeroport kits. The boxes are made right now to not come apart or to make any adjustments. So after the next comp, I will pull the boxes out and put in the 6" aeroport kits. I will also build a box to house both 10s and use the ports on them as well. To see which is better. I will also resine the new box and put 45s in there as well. The next step after that will be to upgrade my alt and more batteries.
those box's have 3 4" aeros each i posted a link (second post of this thread) to the build log of that rex
R.I.P!
(Nov-29-2009)
92 explorer
current build
