last night my car randomly shut off and my battery light came on. i was really low on gas so i thought i ran out of gas. i was moving at about 15 m.p.h. i threw the car into park w/o thinking and it made a bad sound. i turned the car off. i turned it on right away and went and got gas. The car seemed fine right now, but it turned off 2 more tims after that. and it was making a really bad sound like it was the belt or something, and my oil level was really low. when i sat at red lights it said i had no oil at all but when i was driving it said i had oil but it was really low. This morning i turned the car on and all the sounds where gone but my oil was alot worse. and another souns happened as a i drove. There was a sound like popcorn is being popped coming from under my hood and my car tuned off one more time at a red light. the sound got a little bit louder as i revved to higher rpms, but the sound was also there while i was in park. The sound went away right away after i turned off my car. im thinking its the oil but then why would my car turn off randomly and why did it turn off randomly last night. i did florr it like twice last night but i dont think that did anything.
Once or twice I have missed having a back seat / rear hatch, but all in all people love to see a walled vehcile. It just screams "i'm not fucking around with my setup, im loud"
Whyat kind of sound like knocking? If so it could be a spun rod bearing which would make your oil pressure fluctuate rapidly.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
when was ur last oil change? I agree with DJ, sounds like a lifter tap. You may need an oil change. What kinda car is it
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
its a 1998 buick lesabre. i boughht the car week ago and was going to get it inspected on saturday. he started to inspect it last wednesday but something happened and i couldnt get it done until this sturday, but know he has the car, because it broke down later in the day.
  • 4 months later...
Hold the RPM's steady at about 2500 and have a friend listen to your top and bottom end, also have him feel the top and bottom end, If its bottom end its prob a rod bearing, top end is either a broken lifter or some lifter noise which can probably be solved with a good adjustment. And as for your car dying, that kind of goes along with my rod bearing belief..same thing happened with my buddies escort GT. It really sounds like a rod bearing to me..
That oil gauge doesn't tell you how much oil is in your car it tells you how much oil pressure your car has, big difference. I hate to say it but you will probably need a new motor. The "belt sound" sounds like a rod bearing spinning and the "pop corn sound" sounds like lifters tapping from low oil pressure. I hope I'm wrong.
HU: Pioneer
Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2
Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW good.gif
Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back
.ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
