BassAddict32 Posted January 31, 2009 Author Report Posted January 31, 2009 crossfire vr4000 puts our 4000 at 2 ohms,just an idea 4000 at 2 ohms? jesus. lol. i don't wanna kill the things. i just want to have them have close to their max. but thanks for the idea. Quote 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
BassAddict32 Posted February 1, 2009 Author Report Posted February 1, 2009 okay, so does anyone agree with anyone else? i've had like 30 different amps that i could use here but does anyone agree with anyone else so i can figure this out? lol. because i have 2 ideas. 1. get 2 1000w monoblock amps and strap them to 1 ohm or 2. get 1 big amp around 3000 and strap them to 2 ohms. Quote 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
Neo_frog Posted February 1, 2009 Report Posted February 1, 2009 okay, so does anyone agree with anyone else? i've had like 30 different amps that i could use here but does anyone agree with anyone else so i can figure this out? lol. because i have 2 ideas. 1. get 2 1000w monoblock amps and strap them to 1 ohm or 2. get 1 big amp around 3000 and strap them to 2 ohms. More than likely if you buy a 3000W monoblock, you'll only be getting 1500 out of it because your final load will be 2-ohms and your subs will only be getting ~375W a piece. It's not the best idea. I vote the two 1000W amps. You'll be giving the subs sufficient power since each pair will be a 1-ohm load and you'll have less impedance rise which ideally will yield more power. If you really have to have only one amp, like I said before, get a 4000W monoblock. The final load will drop the amp's power to 2000 @ 2 ohms which would be perfect for the subs. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
98HOEONSIXEZ Posted February 1, 2009 Report Posted February 1, 2009 you wont kill them,just dont turn the amp all the way up.i had it on 2 memphis mojos,they were 750rms and 1500 max,i had it putting about 2250 per sub,daily for over 2 years and the subs never failed or skiped a beat,i beat the shit out of them too.HAving alot of clean rms power is alot differerent than having alot of distorted crap coming out of an amp Quote
BassAddict32 Posted February 1, 2009 Author Report Posted February 1, 2009 More than likely if you buy a 3000W monoblock, you'll only be getting 1500 out of it because your final load will be 2-ohms and your subs will only be getting ~375W a piece. It's not the best idea.I vote the two 1000W amps. You'll be giving the subs sufficient power since each pair will be a 1-ohm load and you'll have less impedance rise which ideally will yield more power. If you really have to have only one amp, like I said before, get a 4000W monoblock. The final load will drop the amp's power to 2000 @ 2 ohms which would be perfect for the subs. or should i get the 4000 crossfire like the guy a few above me said? if it puts out 4000 at 2 ohms, then wouldn't i be getting 1000 to each? or should i still go with the 2 amps? Quote 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
creyc Posted February 1, 2009 Report Posted February 1, 2009 More than likely if you buy a 3000W monoblock, you'll only be getting 1500 out of it because your final load will be 2-ohms and your subs will only be getting ~375W a piece. It's not the best idea.I vote the two 1000W amps. You'll be giving the subs sufficient power since each pair will be a 1-ohm load and you'll have less impedance rise which ideally will yield more power. If you really have to have only one amp, like I said before, get a 4000W monoblock. The final load will drop the amp's power to 2000 @ 2 ohms which would be perfect for the subs. Not every amp is 1-ohm stable, you do know? Whomever mentioned the Kicker ZX2500 was smart, that amp does rated power at 2-ohms, which is perfect for his application. You're looking for an amp that does between 2000-3000 RMS at 2-ohms. You COULD run two 1000 watt strapable mono blocks at 1-ohm, but that just seems like more of a bother than it's worth. I used to to run two SAE-1000D's strapped and I'm much happier now running a single 3000D, even though I'm putting out less overall power. Quote 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
Torres Posted February 1, 2009 Report Posted February 1, 2009 or should i get the 4000 crossfire like the guy a few above me said? if it puts out 4000 at 2 ohms, then wouldn't i be getting 1000 to each? or should i still go with the 2 amps? only if you tuned the amp to put out that much power. tuning lower will let the amp run cooler since it wont be pushed so hard. but then you'd have a ton of power left on hand which is good for upgrades...but atm might be heavier on your pocket (not sure on pricing exactly). i'd do the kicker, or strap amps. either or...whichever is cheaper. you'll get close to the same outcome basically either way Quote
BassAddict32 Posted February 1, 2009 Author Report Posted February 1, 2009 so kicker seems to be a good brand for amps. which type of kicker amp should i go for? pricing isn't that big. i just want a good amp to use. and i want to hopefully push the subs to max power. or close to it atleast. around 700W or so is good for me. Quote 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
Neo_frog Posted February 1, 2009 Report Posted February 1, 2009 Not every amp is 1-ohm stable, you do know?Whomever mentioned the Kicker ZX2500 was smart, that amp does rated power at 2-ohms, which is perfect for his application. You're looking for an amp that does between 2000-3000 RMS at 2-ohms. You COULD run two 1000 watt strapable mono blocks at 1-ohm, but that just seems like more of a bother than it's worth. I used to to run two SAE-1000D's strapped and I'm much happier now running a single 3000D, even though I'm putting out less overall power. Notice I said monoblock. And like I said again, less box rise with two amps. Maybe more of a hassle, but more worth the effort, and usually less expensive. And they don't have to be strapped. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
creyc Posted February 1, 2009 Report Posted February 1, 2009 So the Kicker ZX2500.1 isn't a monoblock? lol News to me. Quote 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
