pcchris Posted January 31, 2009 Report Posted January 31, 2009 okay i purchased 4 hifonics brutus 2600watt amps and i want to know what and how many alternators would i need to get them going.... also i want to use kenetik batts in the back which battery model from the kenetik lines should i use and how many for all 4 amps i want to see around 2200 watts from each amp......(on a budget) heres my setup ----------------- 4 hdc318's copper d2 4 hifonics brutus bxi2608d's 1 maxx link stuff just sitting in my living room :-( i want to instqall it already! @DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many -TEAM WOBBLY WOOFERS- 4 18s MAKE YOU SCREAM!
11BangBang Posted February 5, 2009 Report Posted February 5, 2009 Im running 2 Hifonic 1200,s and a Hifonics 600 off of 2 optimas and a stock, and a 220 amp alt everything is wired parallel and works fine. I think if you went with stock, and a 300 amp alt and a kinetik 1800 or 2 in the back you would be fine. Hifonics are not to power hungry. 2001 Tahoe Alpine IVA-W505 2 OPTIMA's RED/YELLOW DUAL ALTs 140/220 (2) HIFONICS BXI1280D (1) HIFONICS ZXI6408 (4) ALPINE SPR-13S 5.25 (4) ALPINE SPR-17S 6.5 (2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
brsteinbach Posted February 5, 2009 Report Posted February 5, 2009 I agree with 11bangbang. 2 Infinity Reference 1252w 12s 4.2 cubic foot box tuned to 28hz Sub amp: 1 Profile AP1200 Speaker amp: 1 Sony Xplod XM-504z Kenwood eXcelon KDC-X492 4 and 8 Gauge Knu Big III In 1/0 All in my 90 Accord Diamonds are forever, but 9's end that shit fast....
c0smo kram3r Posted February 5, 2009 Report Posted February 5, 2009 I say: (2) PowerMaster D3100s in the back (Better than Kinetiks.) Two runs of 3/0 to the back (positive & negative). A 300A alt. 1/0 from back batteries to amps. So yeah, you're looking for at like $1500 at least for all of that.
Neo_frog Posted February 5, 2009 Report Posted February 5, 2009 I say: (2) PowerMaster D3100s in the back (Better than Kinetiks.) Two runs of 3/0 to the back (positive & negative). A 300A alt. 1/0 from back batteries to amps. So yeah, you're looking for at like $1500 at least for all of that. I'd rather see you do two runs of positive 1/0 and ground to chassis. 3/0 is ridiculous and hard to work with if you don't buy the right stuff. You might look into a 225 or 250 b/c the 300s don't have high output at idle. Smaller ones can almost drop nominal at idle. If you're really wanting Kinetik, get the 3800. It's bigger than the D3100 and cheaper in the right places. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
zfrerichs Posted February 5, 2009 Report Posted February 5, 2009 I'd rather see you do two runs of positive 1/0 and ground to chassis. 3/0 is ridiculous and hard to work with if you don't buy the right stuff. You might look into a 225 or 250 b/c the 300s don't have high output at idle. Smaller ones can almost drop nominal at idle.If you're really wanting Kinetik, get the 3800. It's bigger than the D3100 and cheaper in the right places. 3800 are cheaper where? Roseville, CA
Guest KyleCannon Posted February 5, 2009 Report Posted February 5, 2009 I would personally say give robbie a call at dcpowerinc.com. Even if you don't buy your alts from him, he will definitely help get you on the right track with your electrical. As for the batteries, I would do 2 Powermaster D3100s as well.
