I've got my SAZ-3000D running at 2 ohms on my two 15" Havocs and have been more than pleased with the performance. Because my subs are DVC 2 and i have 2 of them, wiring to 1-ohm isn't an option, so I went with 2.
A few people from other forums have mentioned this amp is fairly stable down to 0.5 ohms, even though it voids warranty and isn't technically supported. I'm wondering what the success/failure rate has been with people trying to do this. Secondly would I notice a significant improvement? I don't compete, or meter, I'm more of a street beater :)
As far as electrical I've got a 250A HO alt, yellow top under the hood and a Kicker HC1800 in the back.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
I can't condone .5 ohm use and I'm not telling you to do it.
Positives from half ohm use are more power.
Negatives are added distortion to your SQ,The amp will have to dissapate extra heat it wasn't designed for and you will be taxing all the components in the amp which means a shorter life span for the amp.
I would say you probbly need to keep your voltage above 13.6 volts if not 14 volts at all times to help the amp to keep from blowing or sustaining damage.
To be honest, you shouldn't consider a .5 ohm load except for doing burps,most likely you will blow the amp at some point if you run it at .5 ohm daily.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
What he said.
Not to metion your electrical is no where near up to par to run it at .5 ohms.
Id strongly suggust at least 2 kinitik hc2400s, or 2 powermaster d3100s to run that amp daily as a street beater at .5 ohms.
x2
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Either get two Powermaster d3100 to support the 3000d or trade it in for two Sundown 1500's so you can run each amp at 1 ohm.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
That amp will run all day long @ 0.5ohm but I suggest having two good batteries in the rear to support it daily. Try it out on your current electrical setup but have a volt meter hooked up at the amplfier to see what your voltage drop is like. As long as you stay in the 12s you're fine. You will notice a huge difference in loudness from 2ohm to 0.5ohm with that amp.
Thanks guys, that's kind of what I expected to hear. I don't think I'll be trying 0.5 ohms anytime soon.
Besides 1600 watts is pretty brutal as it is. (although its never loud enough for me ; )
I'm not too worried about the Havocs. Giving 3000 to the pair would be just a tad over rated RMS anyways, as they're rated for 1250 RMS each.
2001 Chevy Blazer
(2) SAZ-3000Ds
Rockford 600-4
I also asked this. I got answers from EVERYBODY saying it would handle it like a champ. Plus, if your power supply blows, it only like a $50 to get it fixed.
I was told from owner of Sundown that you need to stay above 12 volts...which you probably couldn't do w/ your current setup.
Edited by c0smo kram3r
