im checking to see if i oculd wire up 6 sundown e8 subs to 2 ohm they are single 4 ohm subs. i want to wire this up to a single sae - 1200d
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
easy way to figure out ohm loads for bigginers is go to rockford fosgates website. they got an ohm calculator. if they dont have a choice for 6 4 ohm subs then do 3 dual voice coil 4 ohm subs. its the same thing.
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
each coil would be a sub.
In Dash
Rear Flip Down
would i be able to get them down to 1 ohm?? because i would really like to get 200 on each one
or how would i find the load of 8 of those subs actualy? cause i might go that route. maybe even 10. i wish there was a bigger calculater(sp) out there
thats for 8,
for ten of them they would not have a diagram but it would be a 1.6 ohm load
Edit: Are those subs only available in 4 ohms?
Edited by Clif
In Dash
Rear Flip Down
yeah they are only available is single 4. so would 12 make a final load of 1 ohm or under i take it? man this is gonna cost me. at 80 apiece for 20 its just gonna be 800. then with two more possible.hmm. might have to rethink this. cause ill need to still get supplies to make the box and then more wire. ive got all the power wire. and might be getting an amp to push them for my birthday for 120 =] and then ill see if i can get someone to buy me atleast 6 for my birthday. this is gonna be tricky
You only get a true 1 ohm load with 4 subs or 16 subs.
You can get close on either side of 1 ohm with funny numbers of subs but it takes some funky wiring.
10.x volts fo' life!
oh ok thanks. so i might go with 8 but with 4 on an amp. so ill have to get two amps.
mmm no
2*4=8/3=2.66ohm
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
