I want to do a box for 4 15" subs with the port to the back and subs facing the roof. This is going to be my first build do i have to put anything inside the box i see people putting wood inside the box like sticks to hold something please help and post pictures if you could.
ALPINE IVA-S106
AUDIO CONTROL EPIC CENTER
Jl Audio 1000.1 (4)
Jl Audio 300/4 (2)
MTX 9500 (4) 15"
MTX TXC (8) 6.5"
260 IRRAGI ALT
BIG 3
Los Angeles – The gang capital of the world
bump
ALPINE IVA-S106
Jl Audio 1000.1 (4)
Jl Audio 300/4 (2)
MTX 9500 (4) 15"
MTX TXC (8) 6.5"
260 IRRAGI ALT
BIG 3
For 4 15's I would definately reccomend alot of bracing for your box, unless your making it out 1.5 inch steel, so yeah some 2x4's or wooden dowels work good, alot of people use all thread which takes up less space inside the box, just dont forget to account for internal bracing when you calculate your box volume
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
Edit:^^^ Damn You!!!
It's just bracing you can do 2x4's, Inch and a quater wood dowels, All thread its up to you I'd do the all thread. Because it takes up less room and is prolly the strongest.
Edited by etaks_crew
can you put a diagram please im lost. :censored:
ALPINE IVA-S106
Jl Audio 1000.1 (4)
Jl Audio 300/4 (2)
MTX 9500 (4) 15"
MTX TXC (8) 6.5"
260 IRRAGI ALT
BIG 3
basically its like a column in a building... it helps to support it and keep it sturdy. Its recommended for that type of weight and power
so i just put 2 of the side to side to keep it strong and the port size whats the best for more spl and air
ALPINE IVA-S106
Jl Audio 1000.1 (4)
Jl Audio 300/4 (2)
MTX 9500 (4) 15"
MTX TXC (8) 6.5"
260 IRRAGI ALT
BIG 3
theres lots of ways to brace your box heres some wood ideas
R.I.P!
(Nov-29-2009)
92 explorer
current build
I recommend using threaded rod. NAPA Auto Parts or your local auto parts store should carry it in varying sizes and lengths. Hardware stores would as well. Just be sure to get enough nuts/washers to do both sides of the panels.
The woofers might suck all the air out your lungs
(if you stand too close)
When the monster hums
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
