and solder is like welding, vibration isnt an issue, and i will promise you a well done solder will work 5x better then a well done crimp any day, both in connectivity and strength
(i used to crimp, tried soldering, I'll never go back, you could tow a friggin car with 0g and soldered on terminals, most crimps i could pull off by hand with some elbow grease)
Actually a good crimp literally is 'cold welding'
But this requires a proper hydro crimper or a very big hex crimper to do properly. Most people think crimping sucks because they do it badly.
A 'properly' crimped join has both lower resistance and higher strength than a soldered joint ;)
10.x volts fo' life!
x2
only downfall of it is that they dont really look purdy :(
