ok when i strap my amps and play a long bass note the slave amp goes in two protect why?
second ? is 147.5db bad on a termlab sealed up on music with 2 18" and 2 rd 3250.1
and would i be better off unstrapping the amps and just wire the subs to 1ohm and hook up 1 amp per sub they are strapped @2ohms now
Yes I think that you would be better off unstrapping the amps and just running one per sub. You will have less impedence rise per amp that way and they will make more power in the long run. If you have them wired at 2 ohms strapped they are more than likely not making the 2 ohm power. The impedence rise is probably over 4 ohms and is making close to half the power that the amps would make at 2 ohms. As far as the 147.5 with 2 18's, I personally think that it should be louder. I have 2 Sundown Nightshade 12's and a Sundown saz1500 per woofer and do a 149.7 on the dash sealed in my car. A lot of things could be playing a part of it not being as loud as you'd like. What kind of vehicle is it in? What kind of electrical do you have? What are the box specs? These are all things that would make a difference in why the score isn't a lot higher. With the equiptment that you have I don't see why you shouldn't be doing low 150's on music. I would say to check to make sure that one of the subs isn't wired out of phase cause that could have a lot to do with your score too.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
thanks for your reply im going to unstrap them tommorrow and run one amp per sub but i had 2 12's aswell doing 149.4 and then tested the 18's today and was like wtf but it sounds twice asloud with the 18's just low scores and my hatch is comeing up like 3 inchs in the back but tried to hold it down the best we could but maybe after rewiring the sub and unstrapping the amps you think 155 is possable
IMO i dont think you are gonna gain 7.5 dbs just by rewiring subs and unstrapping the amps. You may gain alittle becasue your impedence rise may not be as high. Can we get some more info on your setup? What type of vehicle box size and tuning?
Edited by Billy1987
2000 Monte Carlo SS
Alpine Cd Player
15" Kove Armegeddon
Memphis 1500d
its a 97 ford probe gt hatchback the box was built to treos specs i wens 10cubes before diplacments 100sqin of port and tuned to 32hz and i have a yellow top up front and 2 stinger 2150 in back and i know i need more i will get them later and i have a crx type box subs up port back and they are 2 18" treo ssx subs and 2 rd audio 3250.1 http://i361.photobucket.com/albums/oo51/fa...pg?t=1234489006
http://i361.photobucket.com/albums/oo51/fa...pg?t=1234489046
how was your old setup tuned? with the 2 12s, tuned high? just out of curiosity
Edited by Army_guy614
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
also try moving the box forward more towards the front seats, i found in my car *hatchback subs up port up* the port should be about half way into the rear window and it sounds ALOT louder to me* havent had it metered yet but try moving the box, should help, especially if its under the trunk lid and not firing off the window
Team DC Audio
so does anyone else think wiring the subs to 1ohm and putting 1 amp per sub will help and also when the guy got out his termlab he had to blow the dust off it do you think it may have not been calibrated correctley
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
