lamchop_8 Posted February 16, 2009 Report Posted February 16, 2009 I've seen the new Sundown amp (3500d) and I plan on buying it but I need to know one thing before I do. Can a btl fully loaded handle 3500+ rms for long periods of time without blowing??? Also will I get a 3db increase since thats almost double the btls rated power or not???? Quote Very Very Soon 2 Come??? (1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof) (4):15'' Orion Hcca's (1):Stetsom V 14K2D (6):Kicker PKD1 (Ampkit) Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF (:Screws for terminals (Better solid connection no leaks) (1):Dynamat xtreme license plate kit (1):Kenwood eXcelon KDC-X492 (3):300amp HO Alternators (4):Kinetik HC 3800 Batts. (1)Rockford Fosgate Power T8004 (For Mids & Highs) (4)Rockford Fosgate Power T162S (Mids & Highs) (3):Kicker PKD4 Ampkit (For Mids & Highs) (1):Kinetik HC 1800 (under the hood or yellow top) (1):Viper 5701 (p/n 5202V) ALARM Big III will be done (beefing up my electrical system) etc. Goal:154.9db-159.5db
Boon Posted February 16, 2009 Report Posted February 16, 2009 LoL you and your 'dB increases' - you may gain 4dB over running it at rated, you might gain 0. You might even lose dB, crazy as it sounds. Quote 10.x volts fo' life!
Forevrbumpn Posted February 16, 2009 Report Posted February 16, 2009 Meade runs more than that to each of his 18s and he is pretty damn loud. Its mostly how its installed, dont boost at screwed up frequencies, dont abuse the sub, and you should be fine Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
lamchop_8 Posted February 16, 2009 Author Report Posted February 16, 2009 LoL you and your 'dB increases' - you may gain 4dB over running it at rated, you might gain 0. You might even lose dB, crazy as it sounds. Your right about that. Hope I gain db's!!! Quote Very Very Soon 2 Come??? (1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof) (4):15'' Orion Hcca's (1):Stetsom V 14K2D (6):Kicker PKD1 (Ampkit) Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF (:Screws for terminals (Better solid connection no leaks) (1):Dynamat xtreme license plate kit (1):Kenwood eXcelon KDC-X492 (3):300amp HO Alternators (4):Kinetik HC 3800 Batts. (1)Rockford Fosgate Power T8004 (For Mids & Highs) (4)Rockford Fosgate Power T162S (Mids & Highs) (3):Kicker PKD4 Ampkit (For Mids & Highs) (1):Kinetik HC 1800 (under the hood or yellow top) (1):Viper 5701 (p/n 5202V) ALARM Big III will be done (beefing up my electrical system) etc. Goal:154.9db-159.5db
lamchop_8 Posted February 16, 2009 Author Report Posted February 16, 2009 Meade runs more than that to each of his 18s and he is pretty damn loud. Its mostly how its installed, dont boost at screwed up frequencies, dont abuse the sub, and you should be fine Okay thanks Quote Very Very Soon 2 Come??? (1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof) (4):15'' Orion Hcca's (1):Stetsom V 14K2D (6):Kicker PKD1 (Ampkit) Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF (:Screws for terminals (Better solid connection no leaks) (1):Dynamat xtreme license plate kit (1):Kenwood eXcelon KDC-X492 (3):300amp HO Alternators (4):Kinetik HC 3800 Batts. (1)Rockford Fosgate Power T8004 (For Mids & Highs) (4)Rockford Fosgate Power T162S (Mids & Highs) (3):Kicker PKD4 Ampkit (For Mids & Highs) (1):Kinetik HC 1800 (under the hood or yellow top) (1):Viper 5701 (p/n 5202V) ALARM Big III will be done (beefing up my electrical system) etc. Goal:154.9db-159.5db
Nightshade Posted February 16, 2009 Report Posted February 16, 2009 What Forever said, don't boost at all. Meaning don't use the bass boost on the amp at all! If you turn that up all your going to do is send a clipped signal to your subs and cause them to overheat faster. With that much power and some excess heat from a bass boost it will blow sooner than later. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
gotFI? Posted February 16, 2009 Report Posted February 16, 2009 my buddy runs RF T40001BD to each 18" btl. his birthsheets are 4900 and 5010 rms. hes doing just fine. like the others said, keep that bass boost down (off) Quote
Neo_frog Posted February 16, 2009 Report Posted February 16, 2009 How about instead of worrying where your bass boost is at, just tune from the HU back with an o-scope. It'll take all the guess work out of tuning and giving the subs clean power. I did it for the first time a week ago and it's so damn simple and my gains are all up surprisingly high without any distortion. I really suggest it to everyone. A BTL would take that amp assuming you tuned it properly. Otherwise you'll smoke it. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Jextel Posted February 16, 2009 Report Posted February 16, 2009 i agree with everyone with the bass boost and also dont make an overly large box..8cu ft after displacment and 3500wrms do not mix..you be cool just use common sense... Quote http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive.
lamchop_8 Posted February 16, 2009 Author Report Posted February 16, 2009 i agree with everyone with the bass boost and also dont make an overly large box..8cu ft after displacment and 3500wrms do not mix..you be cool just use common sense... So you guys are saying I can give it the whole 3500+rms but dont turn up the bass boost and I'll be fine?? becuase my subs are going to be getting a lil over 6 cubes a piece that is'nt too much for that much power is it??? Quote Very Very Soon 2 Come??? (1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof) (4):15'' Orion Hcca's (1):Stetsom V 14K2D (6):Kicker PKD1 (Ampkit) Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF (:Screws for terminals (Better solid connection no leaks) (1):Dynamat xtreme license plate kit (1):Kenwood eXcelon KDC-X492 (3):300amp HO Alternators (4):Kinetik HC 3800 Batts. (1)Rockford Fosgate Power T8004 (For Mids & Highs) (4)Rockford Fosgate Power T162S (Mids & Highs) (3):Kicker PKD4 Ampkit (For Mids & Highs) (1):Kinetik HC 1800 (under the hood or yellow top) (1):Viper 5701 (p/n 5202V) ALARM Big III will be done (beefing up my electrical system) etc. Goal:154.9db-159.5db
