Sundown Amp Stuck In Protect :(
Torres
alright so lemme break it down to you real quick...my *master* sundown amp is stuck in protect. the slave is fine, just the master. last night i installed 1 of 2 new batteries. all in fine and dandy. i let them trickle charge overnight, and before i started the charge, i disconnected the power wire from each amp (a long while ago i jump started it with one and my old amps popped and smoked a lil...so i wanted to play it safe even tho it was a 2 amp charge). so that was the ONLY thing i did to the amps or anything back there.
so this morning i disconnect the charger, rewired the power wire and head to class. after about 30 minutes of driving, the bass just stops. it wasnt full blast, probably at about half volume. my voltage was fine. it took hard thumping to get my voltage to drop...which at that listening level wasnt enough. especially with my added battery. i checked my wires. all wires were firm. i took the RCA's out and tried to turn it on (was told that might be the problem). took the wiring out and let it sit and tried again and still nothing. it's stuck in protect mode.
any ideas? i'm lost. i tried searching but to no avail :cray:
did you test for voltage coming out of the speaker leads?
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
maybe a fried transistor???
2001 chevy silverado 1500
h/u- pioneer avic-f900bt and custom molded 7 inch monitor in center console
mids/highs-memphis m-class 6.5 component set
subs-3 kicker L7 12's seprate chamber box at 43hz and aprox. 3 cu. ft.
amp- treo ssx 2000.1
all memphis 0 gauge wire and rca's
Plans- 2 treo ssp 18's
kinetik 2400 batt and a mla module and high amp alt
focal 6.5 components and amp
not yet. i worked night shift so i'll have to try tomorrow after work. if i get nothing, bad power supply?
i was hoping it'd be an easy fix...just somethin i looked over. if i get no voltage i guess ima have to take the amp out and stick my nose around in there
i would guess the output stage. but i dont know much about repairing amps
DC.jpgDC POWER
i dont think if it was the output drive the amp would drop into protect.
my Z1 had NEVER went into protect, but my output drive was blown. no smoke, no humming or nothing just no sound at all. green power light, just no output.
hopefully Boon will chime in.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.gif
DC.jpgDC POWER
that's what i woulda thought, being as no voltage coming out. but i dont think it'd go into protect either, just no output. i asked my friend about it and he says if i get even as little as 1 volt, it's bad at the power supply
  • Who's Online   0 Members, 0 Anonymous, 686 Guests (See full list)
