Torres' Box Tuning Calculator - Updated 8/18
Torres
From the help/FAQ
7 - Port length uses the box wall or baffle(s) as part of the port length.
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
From the help/FAQ
If you are uneasy with that method, just use whatever you enter as port length and measure along the center line end to end, like in the yellow line:
This is the simplest straightforward way and works without any considerations of baffle thickness. etc.
  • 1 month later...
Does the Torres Calculator account for the added length of an aero port due to its flares? Or are we to add 1" to the physical length?
Check the following:
With the diagram above find out what's the effective length of your port and enter that to the calculator.
Hey..
M facing some problem while designing the multi baffle enclosure..
Here is my question: when we design a multi baffle enclosure then the thickness of the second baffle is included into total external depth of the enclosure..?
#Joe if possible help me with a diagram this will be appreciated..
RDD *ROHIT DUDEJA DESIGNS*
And is this possible to use a master baffle of 1" thickness and slave baffle of 5/8 thickness..?
If yes? Then we have to fill the total thickness of baffle i.e. 1" + 5/8" = 1.625" in the port thickness section..?
  • Who's Online   0 Members, 0 Anonymous, 1105 Guests (See full list)
