Torres' Box Tuning Calculator - Updated 8/18
Torres
sounds like probably too much port area and/or not enough port length. try starting a topic in the enclosure section with box specs and whatnot, probably get more responses there. i'd like this thread to remain about comments/suggestions/criticism about the calculator please.
Will do, thanks!
im trying to clean this up so its only useful information. If youd like to have a question answered please create a new topic.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
calculator questions are fine, but yeah i don't have the time really to help design and tweak boxes. thanks nate :)
as for the update i've been talking about, it's pretty much done, just adding in different colors of backgrounds and font colors to choose from in case people want it other than just gray. still working on a printing issue, but don't know if it's within my means to fix it, we'll see tho.
i have a quick qestion. When you are puting in all your box dimensions and port sizes in the point is to get the "Port Area" in the "Port Area Range" to make your box function right? what does it do if you go higher or lower on the "Port Area"? Or am I way off? :noob:
no, it's not a puzzle to get port area in the range lol. port area range uses the general rule of 12-16 sq inches of port per foot (which i have taken out on the new one). so it's just that...a general rule. you can use more, or less, just depends on the whole install/vehicle/etc.
so if my box is 21D 28W 16H and i want port and sub up, how would i set that up in torres? with a 3" port opening and 32hz?? would i have height set to 19.5, width 3, length 22??? sub is incriminator audio lethal injection 15, off a hifonics brutus 1200,
why shorter dimensions? to account for wood thickness? the calculator takes that into effect automatically. which can be adjusted to bigger/thinner thicknesses with the bullets by the different thicknesses.
to do sub up/port up, just click the sub and port up check boxes
