Torres' Box Tuning Calculator - Updated 8/18
Torres
i use to get this program before, now with this media fire i cant get it to save my life what are the tricks or what am i doing wrong
Got it., had to move the .uexe outside the .zip, got rid of u changed it to .exe and it works now. Bootcamp FTMFW btw for you mac users.
Sir I've got a question on the calculator. I'm not bashing at all I love this thing just wish it was around twenty or so yrs ago lol. When doing box layouts I notice that the volumes are different than mine on paper and real mesurments. I put in my figures in the desired spot is this what needs to be done sir? Or do I need to reinstall the program. Like I said I'm not bashing or complaining just wondering.
that is correct. if you have just box measurements, put that in the desired gross volume box. that way when you enter displacements and port measurements, the additional displacements will be taken out. if you know what net volume you want, then you put that in the desired net volume box so you can adjust the port to how you want with the set net volume. but to me it sounds like you want to put yours in the desired gross volume
and glad you guys got it working. i finally got a new version of visual studio to use, and i'm hoping to get it to an installer package rather than working from an executable file. hopefully that will prevent a lot of problems
Yes sir, that is what I meant to say sorry. This is what I did with the box that is going to be built. I think I messed up on the woofer displacement though.
If it makes any difference 10 12" subs are going in this box. With the woofer displacement the tuning is going to off now crap. At least I just have to redo the port lol.
just as a note, any number in the 'desired gross volume' text box will override any dimensions you have entered in for the box. and likewise, any number entered in the 'desired net volume' text box will override both the 'desired gross volume' box as well as any dimensions entered. so right now the calculator is seeing 19.2 as net volume, and nothing as gross volume from the dimensions entered nor the 'desired gross volume' text box
Thanks at least I have a chance to correct it. So does this make the port figures off then. I'm trying to learn to use this to it's fullest and correctly. So I can play with more box builds for me. But thanks for giving more understanding of how this works. I can only read so much of the instruction before it stops. Do you think this will still work the way it is laid out. I'll post anymore box questions in the right place after this. Thanks
hey torres i am using your box calculator to design a box for 2 12's with a slot port with 2 common walls which is the one in the middle of the two subs i believe? i just wanted to run my specs by you and see if i did everything right.. im not sure..
edit: just found out how to attach pics.. please let me know if i messed up anywhere? thanks!1.png
2008 BMW 550i M Sport
Build coming soon!
2000 Volvo s40 1.9T
Pioneer DVD navigation head unit
O2 audio performance mid range speakers
2 Crescendo PWX-6 Pro Mid Range Speakers
2 Crescendo PWX-8 Pro Mid Range Speakers
4 Selenium ST200 Super Tweeters
Hifonics ZRX2000.4 Amplifier
2- 12 inch DC Audio Level 4 m2
Hifonics Brutus BXI-1610D Amplifier
2 KinetiK HC1400R- Secondary Batteries
Kinetik HC600- Secondary Battery
Knukonceptz 1/0 gauge big 3 upgrade
