Torres' Box Tuning Calculator - Updated 8/18
Torres
what you need to do is go to the folder that it's in, and click tools up at the top (click alt if you can't see the tool bar) and then click folder options. then click the view tab, then in the advanced settings window, there's a check box that says 'hide extensions for known file types'. uncheck that and then you will see the file extension. take out the U now and save it. then you can go back and check that box again to hide the file extensions
Still having an issue the program finally downloaded but will not run. I get a pop up saying the file is not compatible with the version of windows that I am running. And to contact you about what this program is a 32 or 64 bit version. I have a toshiba satellite with a i3 core processor 64 bit. I'm not that computer savvy so I was wondering if you could explain if I'm doing something wrong. Thank you
do you know what version of windows you're running? and is it saved as a .exe or .uexe? PM me with the details, i'm sure we'll get it working
got it thanks!!
i think theres an issue with it, i put in 15h x 36w x 21d and it tells me my net space is 2.26 before i do any port dimensions or driver displacments... it should be well above 4 cubes at that
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
me too
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
That's odd. There shouldn't be any complications with the calculations, I didn't mess with those. I'll check when I get back home tho. Wood thickness is .75"?
