BassBoy69 Posted February 22, 2009 Report Posted February 22, 2009 Ok so I have hit from 135.6 - 137.5 on 1-10" Bl - If I get one more bl- and one more of the same amp,.. what do you think I would be hitting at from there? 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
Neo_frog Posted February 22, 2009 Report Posted February 22, 2009 Ok so I have hit from 135.6 - 137.5 on 1-10" Bl -If I get one more bl- and one more of the same amp,.. what do you think I would be hitting at from there? I'm gonna tell you this right now...that is impossible to answer. It will be louder and you will be moving more air, but as far as SPL you most likely will go up, but how much can't be determined. Try it out! Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
CrashHole Posted February 22, 2009 Report Posted February 22, 2009 +1 on what Neo said. No matter how hot she is, someone, somewhere, is sick of her shit. 99 Tahoe: 2-10" MA Audio 4-6.5" Kenwood door speakers Total Amp Sony HU
BassBoy69 Posted February 22, 2009 Author Report Posted February 22, 2009 I'm gonna tell you this right now...that is impossible to answer. It will be louder and you will be moving more air, but as far as SPL you most likely will go up, but how much can't be determined.Try it out! your right,.. I didnt expect a pure number form answer, I was just seeing if anyone knew the before and after of there own set up.. when adding another sub.. if anyone kinda had a bassline number thanks 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
Nightshade Posted February 22, 2009 Report Posted February 22, 2009 Actually it can be answered to an extent. When doubling your cone area you can gain a maximum of 3 db. That is under the perfect conditions and the perfect enclosure. I've only seen a 3db increase a few times. A safe rule is to expect a db or so cause it's very hard to get 3. You will also gain a max of 3 db when you double your power, but still rarely happens unless the conditions are perfect. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
BassBoy69 Posted February 22, 2009 Author Report Posted February 22, 2009 Actually it can be answered to an extent. When doubling your cone area you can gain a maximum of 3 db. That is under the perfect conditions and the perfect enclosure. I've only seen a 3db increase a few times. A safe rule is to expect a db or so cause it's very hard to get 3. You will also gain a max of 3 db when you double your power, but still rarely happens unless the conditions are perfect. ok with that said,.. because i wanted to end up with 2-10"bl's and 2-amps or would i be better off useing 1-12" Btl and have one big amp on that? if thats a dumb question sorry, 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
Neo_frog Posted February 22, 2009 Report Posted February 22, 2009 http://www.stevemeadedesigns.com/board/ind...?showtopic=6819 Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
BassBoy69 Posted February 22, 2009 Author Report Posted February 22, 2009 http://www.stevemeadedesigns.com/board/ind...?showtopic=6819 thanks alot,.. that will help alot 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
Torres Posted February 22, 2009 Report Posted February 22, 2009 if you had the same amount of power from the one big amp as the 2 smaller ones, i'd go with the setup with more cone area
