would i get more output from a Kicker CVR or a KENWOOD KFC-W3011
both are 12's
both are rated at 400rms
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Man unless Kenwood has changed. You will be better off with a Kicker amp.
Hell compared to Kenwood you would probly get better Results off of the old Kicker Impulse line witch used to be thier entry level amps back in the day. (No longer in production)
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
i think hes talking about subs. I would probably go with kicker over kenwood in all applications... except for maybe sq, and even then i still might go w/ kicker
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Kicker is a lot better than Kenwood IMO
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
Whoops your talking about subwoofers.
Yes the Kicker Comp VR should be a better subwoofer but I have not heard the new Kenwoods but the old ones, well you would never find one in any of my installs.
