if its a mechanical sounding buzzing, I would check your dome, use a fingernail, or something that can almost fit between the dome, and the cone, and just kind of walk around the dome, and see if there is any spots where the dome might be slowly popping up
domes when the glue is failing, usually have a buzzing sound
if you can do an actual sweep from like 1000hz - 20hz or so, and if you hear the buzzing more at a higher freq like 100+ hz, it can be the dome
also check the terminals, see if they might have popped lose, either the nut that holds the terminals in place has loosened up, or if the terminal itself is broken
spider pulled off?
sounds a bit like overexcursion...may just be unlucky, wtvr
glue it back, get someone else to glue it back, or get a recone if there just no way to glue it back
Team DC
Reglue it with some 2-part epoxy or CA and you should be sweet :)
Edit: Springy plastic clothes pegs work well for holding it while the glue dries too.
How big is your box? I imagine it would take some serious unloading to cause that...
Edited by Boon
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1703 Guests (See full list)
