L561W Posted March 5, 2009 Report Posted March 5, 2009 I am planning to build this box for the 2 Alpines I mentioned in an earlier topic. It comes out to 6.2 gross, 6 cubes net. The port is 5x8.5 and it's tuned to 32hz according the the12volt.com port calculator. Is the shape and port placement a bad idea? Or do you see anything else that would be a problem? The port is on the side because of the odd shape of the box. Trying to save as much trunk space as possible. Thanks
77-AUDIO Posted March 5, 2009 Report Posted March 5, 2009 I am planning to build this box for the 2 Alpines I mentioned in an earlier topic. It comes out to 6.2 gross, 6 cubes net. The port is 5x8.5 and it's tuned to 32hz according the the12volt.com port calculator. Is the shape and port placement a bad idea? Or do you see anything else that would be a problem? The port is on the side because of the odd shape of the box. Trying to save as much trunk space as possible. Thanks use this one its real nice, and easy to use. http://reaudio.com/speaker_box/LPort_Box_Calc.html PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
raytard Posted March 5, 2009 Report Posted March 5, 2009 pic would be nice sideport is almost always fine, just make sure you have one port width from the port to the side of your car at minimum, any less and some funky stuff happens. (you said yours was 8.5x5...so make sure you have like 8 inches between the box and side of the trunk to allow for airflow) Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
07sOnAtA sp.ed Posted March 5, 2009 Report Posted March 5, 2009 mot enough port area for 6 cubes 2x CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
L561W Posted March 5, 2009 Author Report Posted March 5, 2009 pic would be nice I'm trying to find a way to get it on the net... Photobucket is blocked here wtf
L561W Posted March 6, 2009 Author Report Posted March 6, 2009 So how much port area do you guys suggest?
Cr@sh Posted March 6, 2009 Report Posted March 6, 2009 for 15's usually 16 cubic inchs per cubic ft of box space. for sql tuning. My old install at cardomain, never finished!
L561W Posted March 6, 2009 Author Report Posted March 6, 2009 for 15's usually 16 cubic inchs per cubic ft of box space. for sql tuning. What about for 12s?
