I recently bought some speaker wire for my amp to my box then from my box to my subs. I bought the Monster 402 XLN Xtreme cable. 2 conductor. Need a terminal cup for my boxes. where can i get some? I checked radio shack and they didn't carry any type of terminal cups for high performance audio.
thanks.
-Nick
Parts Express, for sure :)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
use ring terminals and bolts with washers.
no chance of an air leak, and probably less resistance.
Your local audio shops should have some, or even best buy usually has a pair on the shelf.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
X2 best way to go! Need Ring terminals too!!
thanks ya'll. i will probably go with the ring terminals. any chance any of ya'll know what size i might need? in any case wheather i choose the terminal cups or the ring terminals? it looks like pretty thick cable in regards to normal speaker wire i've seen in the past that connects to the subs.
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
