i have an enclosure that is 23" tall x 23" wide x 38" deep for 1 18" lvl 4 xl. My box has 45s in every corner and is also braced. Should i buy some resin and just coat the whole inside of it to seal the pores in the wood? would it be worth buying any fiberglass sheets or is that really just for strength and support. Thanks in advance.
It definitly wouldnt hurt to glass the inside of the box. Itll strengthen the box and make it less likely to break
If you have large, unsupported walls a nice thick layer of fiberglassing (with mat) will help out there...but if everything is stout and supported you could do a nice smooth coating on the inside to seal everything up n such
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
i have some 1" wooden dowells bracing in there. where can i buy resin from? home depot? lowes?
yup, i jus stocked sum tonight at lowes so i know they have it :good:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Pretty much anywhere, yea...both those will have it back near the epoxy's, glues, etc.
Team Tupperware
I did a single layer of chop and resin on the inside of my ox and definatly noticed a smoother sound. Im starting a new box build on Wednesday but will not be glassin it as its super fuckin messy and not worth the results to me. Plus it aint cheap. 45s and bracing seem to serve me well enuff. Like I said I did notice a nice smoother sound in the bass though.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
No it would definatly help with sound proofing the box and like i said youl notice a smoother sound. I just done think it is worth the extra money (about 40 bucks for a quart of resin and 2 packs of matt) since I go through enclosures like I do underwear. If you do it get the clth though and just cut squares to cover each wall. It will come out some much easier than trying to put chop down.
