kentb Posted March 10, 2009 Report Share Posted March 10, 2009 what is the best way of attaching plexiglass to mdf? is it just by using nuts and bolts? also, what kind of vinyl sticker did meade use on this? thanks for the help! Quote New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System Link to comment Share on other sites More sharing options...
kentb Posted March 10, 2009 Author Report Share Posted March 10, 2009 anyone? Quote New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System Link to comment Share on other sites More sharing options...
David Posted March 10, 2009 Report Share Posted March 10, 2009 I used normal wood screws to attach the plexi, pre-drill ur holes first tho. frosty vynal sticker is what was used. Quote Link to comment Share on other sites More sharing options...
kentb Posted March 10, 2009 Author Report Share Posted March 10, 2009 I used normal wood screws to attach the plexi, pre-drill ur holes first tho.frosty vynal sticker is what was used. k thanks! im just concerned that the plexi might crack or something. Quote New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System Link to comment Share on other sites More sharing options...
The Performer Posted March 10, 2009 Report Share Posted March 10, 2009 Stick up some pics of your design and I'll give you some ideas. Just in general if it was me I would put T-nut's in the mdf, then have the plexi, then a trim ring over the plexi. Machine screws (recessed in the trim ring) (hex head's would look good) trim ring on top of the plexi, then a weatherstrip seal all the way around the plexi between the glass and mdf to give it a good seal. If you're not going to be able to do the trim ring then atleast machine screws in the plexi with wide washers. If I were to go that route I would paint a strip around the edge of the inside of the plexi to hide the weatherstrip underneath. It will look goofy if you see the weather strip. Quote CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner Link to comment Share on other sites More sharing options...
David Posted March 10, 2009 Report Share Posted March 10, 2009 yeah thats why you pre-drill the hole, also u want to use a foam backing of some sort between wood and plexi like weather stripping. Quote Link to comment Share on other sites More sharing options...
bobonit Posted March 10, 2009 Report Share Posted March 10, 2009 What thickness of plexi is good enough for a ported enclosure with 2 15" nightshades? Just a window, not the whole thing Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log Link to comment Share on other sites More sharing options...
David Posted March 10, 2009 Report Share Posted March 10, 2009 3/4 minimum Quote Link to comment Share on other sites More sharing options...
C 45. Posted March 10, 2009 Report Share Posted March 10, 2009 you can use 5/8 with out a problem in most applications if your going to be pre drilling your holes make sure to get plastic/plexi drill bits they are different than your normal drill bit more of a point at the end easily obtainable at your nearest taps plastic etc when you drill the wholes be sure to go in a lil bit than back out push in pull out (thats what she said) you get the idea yes and also use weather stripping between the two single sided adhesive 1/2 inch thick foam tape Quote must be nice huh Link to comment Share on other sites More sharing options...
bobonit Posted March 10, 2009 Report Share Posted March 10, 2009 you can use 5/8 with out a problem in most applications if your going to be pre drilling your holes make sure to get plastic/plexi drill bits they are different than your normal drill bit more of a point at the end easily obtainable at your nearest taps plastic etc when you drill the wholes be sure to go in a lil bit than back out push in pull out (thats what she said) you get the idea yes and also use weather stripping between the two single sided adhesive 1/2 inch thick foam tape I already have a Craftics drill bit, but I've never used it, so thanks for the "In/Out" tip Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log Link to comment Share on other sites More sharing options...
