Friend's got 2 JLw3v3 and well, they just stop hittin, dont seem blown so i'm thinkin amp..any info on steps we can take to see if his amp is putting out power any more or not?? info appreciated.
does the amp still turn on?
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
is the protect light on the amp on? are there any lights on?
if it is goin into protect dissconnect the speakers and then try turnin the amp on.
do you have acess to a multi meter? check the voice coils on the speakers..
if the amp comes on. and isnt in protect. hook up the multimeter to the outputs. set the meter to ac volts. and play a song.. see if you get anything coming out... also trace back your rca cables and remote wire.. make sure they arent cut anywhere along the way.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
is the amp in protect
check the RCAS check the power ground, check the wires going to the subs...check the settings on ur amp...check the fuse...
Eclipse cd7000
also if u can try hooking up another speaker or 2 to the amp to see it it pushes them ;)
Edited by finkster
Eclipse cd7000
cerwinvega couldnt have said it any better...also just check your speaker wire going into the amp, or comin out of the box, they ma have shaken loose. if the amp isten coming on at all check your ground, than your fuse.....you may have blown it. if all of that is good follow the instructions above.
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
what kind of amp?
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
if your too lazy to take the woofers out of the box.. just apply a short burst of dc power to the speaker wires to see if they move or react.. a square nine volt will suffice.. just tap it for a quick second. DO not leave the leads on the battery.. (this is purely to see if the woofer still works )
(only do this if you dont have a digital multi meter)
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
according to my friend..the amp isnt in protect and multimeter shows that it IS putting out power, and he swears that his subs arnt blown but thats just what he says...
  • Who's Online   0 Members, 0 Anonymous, 1483 Guests (See full list)
