hmm, basics:
slot port is easier to build
slot port adds strength
slot port has a higher tendancy for turbulence since it uses 90degree corners
slot port is cheaper
round port if flared are more efficient
round port costs more to make
round ports are a bitch sometimes to mount, as they need support internally so they dont move
round ports are not the same as aeroports
in small boxes round ports sometimes need to utilize curves, which if u arent handy, can be a pain also
aeroports>slot>round IMO
i could have added alot more
Edited by decafcappucino
Pretty much x2 ^
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
the one thing i like about round ports is that you can make them as long as possible in the box and then cut them down to tune them to ear (frequency of the vehicle) fairly easy.
I'll let you know what I think of my aeroport in about a week. I am going on leave Monday and building 4 cubes with a single 6" aero for two SeXXX 12's. 'Tis gonna slam.
hmm, basics:
Very helpful thank you!
You don't need as much port area when using aero ports.
Round port take up less air space.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
I think round ports are easier myself. Build the box then play around with the port length to your liking, as stated.
I want to do this actually and, to me, the L ports are going to be a bit tricker and non-adjustable.
  • Who's Online   0 Members, 0 Anonymous, 3139 Guests (See full list)
