slugdub Posted March 16, 2009 Report Posted March 16, 2009 (edited) I also need a new AGU fuseholder and maybe a new positive battery terminal? I tried going to Home Depot for some wire but the stuff they gave me is not flexible, its like a different kind of wire all together. I'm not 17 anymore, so that won't fly. LOL, I only need 2 feet. I want to redo a tiny section coming from my firewall to the terminal (already have the rockford stuff run that far). Also, I don't even see anything that will really connect that kind of wire. Obviously I'm not going to use wire nuts. Edited March 16, 2009 by slugdub Quote
Noobtastic14 Posted March 16, 2009 Report Posted March 16, 2009 sounds like you either need to find your local audio shop or ebay -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
EricM9104 Posted March 16, 2009 Report Posted March 16, 2009 Knukonceptz Flex wire ftw Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
slugdub Posted March 16, 2009 Author Report Posted March 16, 2009 (edited) Yeah, I'm just too lazy and cheap to have something shipped, so wanted to know if maybe Radioshack or.. something. Maybe a website I can order everything from at once to save time & money too. I know best buy has the things online, I just want some other ideas. Now I'm doubting myself when I say 8 gauge, because this inline fuse I ordered showed up and it said 8 gauge, but its smaller than the rockford wire I got comin out... hmmmm maybe its 4? gauges seem to differ from houses to boats to cars somehow. Edited March 16, 2009 by slugdub Quote
uhoh_45 Posted March 16, 2009 Report Posted March 16, 2009 if you've got a princess auto they wire for cheap there Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
slugdub Posted March 16, 2009 Author Report Posted March 16, 2009 if you've got a princess auto they wire for cheap there Who you callin a Princess? Lol, I checked, and those are close-ish, but I'm in Minneapolis. Not Canada yet Quote
slugdub Posted March 16, 2009 Author Report Posted March 16, 2009 (edited) I think I need help before I hurt something. Here is the amp that is ordered: http://www.crutchfield.com/S-mxaLuNGc7Uv/p...rence-611a.html Says 4 gauge recommended, so don't know how 8 will be. (edit: 6 gauge minimum hmm) Also, I am presuming a 60 amp fuse is adequate, although presuming with fuses seems dangerous. Edited March 16, 2009 by slugdub Quote
randomsuper Posted March 16, 2009 Report Posted March 16, 2009 bigger is always better when it comes to power wire. i never use anything less than 2 no matter how little power i'm running. that way if i eve upgrade, i'm covered. Quote
camino_1to3 Posted March 16, 2009 Report Posted March 16, 2009 I think I need help before I hurt something. Here is the amp that is ordered:http://www.crutchfield.com/S-mxaLuNGc7Uv/p...rence-611a.html Says 4 gauge recommended, so don't know how 8 will be. (edit: 6 gauge minimum hmm) Also, I am presuming a 60 amp fuse is adequate, although presuming with fuses seems dangerous. That amp clearly says discontinued. If you want to buy all your electrical needs at one time, go Here or Here Quote Team T3 Audio Team Sundown Audio Team O.B.M Operation Beast Mode "Believe half of what you see and none of what you hear" wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
slugdub Posted March 16, 2009 Author Report Posted March 16, 2009 What is wrong with a discontinued amp? The one flaw they have is the plastic brackets... very fragile. Quote
