Want to build a box for two cvr 15s. (For my Tahoe) Also, what brand/size amp would anyone suggest? (I have a 1200 or 1500 watt kicker amp, gotta find it first, I have YEARS of shit in the garage!)
"loud 'cause its clipped like a 7yr olds buzz cut" -Decaf
"unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
get the dual 2 ohm subs wire them to 2 ohm and find an amp that will produce about 1000rms at 2 ohm. my kicker 750.1 did them great. its rated at 750 but i had it benched at about 850. as far as a box go with exactly what kicker says. in the experiences ive had with my cvrs they dont like to be tune realy low.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Cool....so, ya think the amp I have would be to much? (If I can find it! LOL)
no, it should be fine. just make sure you can find it.
and don't tune the box anything lower then 35hz
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
You say go wit what kicker says....this is what they say:
Ported Box Volume (cubic feet) 3 - 5
Port diameter (inches) N/A
Port length (inches) N/A
How would I figure these, if they don't even have specs?!?
Soooo....no box ideas/suggestions, other than "go with what kicker say" ? I haven''t found my amp yet, think maybe somebody jacked it! ( The back door is opened to the garage at all times, so the dogs can go in and out.) I am using a friends craptastic prefab box ( to small! ), and even more craptastic "JENSEN POWER" 880 2 channel. amp (800 watts my ass!) My first set up was small, 2 12s, a pro box, and a JBL 300.1 mono amp, with a 4 gauge wire kit. NOW....I put this stuff in on the fly today, adjusted everything, and anything over 20 (volume) it goes into protection mode, and either one of the two fuses on the amp, or the fuse under the hood! (the amp fuses are 30s, and under the hood was a 50, I put a 80 in it now.) Do I need to run bigger wire, or just find my amp/buy another one? A LITTLE HELP WOULD BE NICE....PLEASE!
Well, using the12volt.com calculator, I came up with this :
( I'll use 3/4" MDF on this box. )
W 36"
D 26"
H 18"
Port Width 2 1/2"
Port Heith 16"
Port Length 5 1/2"
8.07 cubic feet
Tuned to 35 Hz
Do these measurements look good/right? If anybody comes up wit something different/better, or has any suggestions, please let me know! THANX
should work out. make sure its braced god though.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
From the math im doin hes only gettin 40sq in of port, he needs close to 100-120 lottsa port noise in ur future try widening the port ull have to play with the length too until u hit the tuning u like put it up again but idk if i would go with this design just my .02
pls correct me if im wrong.....
Edited by Moore941
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
  • Who's Online   0 Members, 0 Anonymous, 462 Guests (See full list)
