troy
I think Got_Bass89 has CVRs
four 12s doing 146s
-Drew
uhoh_45 said:
haha ok i got you. do you know any one that has ever competed with cvr's
I used too...
I had two 15's in my trunk car doing a 146.5.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
so technically i could make myself be in the 139.9 class by changing something to make it meter lower
You wouldn't have to change anything just turn your stereo down a little bit at the end of the bassrace run. Did you do a 140.3 just on music, or was it a bassrace run? If it was done on just music you might not be able to do a 139.9 In order to do a 139.9 your car must be able to do a 141 or so constantly on music to keep the average up since you have voltage drop and the variance in the beat of the music. I can barely do a 129.9 in my wife's car cause the car is metering at a 133.4 It just doesn't have a ton of power behind it. My car is a different story. I can do a 149.3 in bassrace but I bassrace in 139.9 cause I can't do a perfect 149.9 My car is burping way over a 150 but since I can't keep the voltage steady I run in 139.9 where I have over 10 db of head room. It's better to run in a class where you have a little bit of room instead of trying to struggle to get to your number.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
four 12s doing 146s
burp or music.
any other numbers?
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
iirc 144-145 bass race (does 139.9 class with headroom) and 146+ max spl on music. no tones, no burps
-Drew
no that was a 3 sec 40 hz test tone
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Sounds like youd br mid 30s, might have to practice in the 129s before moving up
-Drew
is bass race music or tones?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
music averaged over 30 seconds
I do box designs.
so i was metered playing jeezy airforces at 136.9. i would go down to the class lower and try to get a 129.9?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
