I was wondering how yall would connect two runs of 8 awg to a single terminal shown below.
I was thinking I could splice into the main wire coming from the amp then run it to the other terminal?
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
could do a number of things
could put in a T from one wire to 2 out to sub or you could just run 2 wires to the amp or you could try and shove it in the terminal
0 gauge wire ran to the subs they just trimmed it down a little
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
and the 8 awg does not fit in the rear entry...I had to trim like 3 out of 8 twists of wire to even barely fit.
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
...What subs are these?..
And about the wiring...Just run 4 seperate 8 awg runs to the sub, then connect both positives and both negetives at the terminal (bolt) on the box. Or if you just want to run the wire through the box, just trim a little off of each.
Edited by rmzsuzuki89
thats an understatement lol
:01nocomment8so:
Juan Rodriguez
Chief Technology Officer
D'Amore Engineering
T15KW Support Engineer
System.
KVT512 Kenwood Fold Out Monitor
Epic-160 Audio control Indash epicenter
(1)T1500-1BD with T2000.1 Transformer 1700 watts at 2 ohms
(2) T600-2 with T800-2 Transformers 320/ch at 4 ohms
(2) QSD216 Q series MB Quart 6.5 inch components
(3) P3D212 Rockford P3 12inch Subs
(1) Very Loud Altima Coupe!
cactus sounds mk1 15-18s
and for the OP if you want it to be a nice install clean and all this crap use a distro block on the outside of your box from one wire going out to 2 to the subs
R.I.P!
(Nov-29-2009)
92 explorer
current build
Just strip like an inch of insulation and get 3 zip ties, let the wires unravel completely, mash them together, then zip-tie it, keep tightening the zipties for a couple of hours and they'll eventually mash together into something the size of 1 8ga. Add lots of tape :)
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 2347 Guests (See full list)
