tequila Posted March 20, 2009 Report Posted March 20, 2009 Probably a noob question but... Im gonna be running my soundstream t4-15 on 1000watts rms in a 5.24cube enclosure tuned at 35hz. (5.24 after displacement.) I was reading somewhere that a too big a box can damage your woofer and decrease its output.. I immediately looked up vids on youtube of 15" woofers (se, sx, bl, btl) to find out what other people's box dimensions are, and they all seem to be around 4 or 4.5cubes.. Can anyone clear this up for me? Thanks! '99 Civic hatch 18" AA Chaos - 7cuft @ 34hz - 114sq in. port Mac Audio Fearless ~ 1000wrms @ 2 Ohms Videos: Youtube
uhoh_45 Posted March 20, 2009 Report Posted March 20, 2009 * RMS POWER (WATTS) : 1000 * VOICE COIL DIAMETERS (INCHES) : 4.0 * MAGNET WEIGHT (Oz.) : 250 * FREQ. RESPONSE (Hz) : 20 - 1k * Fs (Hz) : 34 * Qes: 0.449 * Qms: 3.722 * Qts: 0.401 * Vas (Ft3) : 2.08/58.77 liters * Xmax (INCHES) 0.551 * SPL (dB) : 91 * HOLE SIZE (INCHES) : 14.25 * WOOFER DEPTH (INCHES) : 8.25 * RECOMMENDED ENCLOSURE (Ft3) : Ported 4.25 * RECOMMENDED ENCLOSURE TYPE : Vented * AEROPORT DEMENSIONS (INCHES): 3 x 3 (2) * Cast Aluminum Basket * Dual 4-Layer, 1-ohm Voice Coils * Cloth Laminated Paper Cone with MD6 coating * Stone Gray Finish with Diamond Cut Edge * Hi Arc, High Excursion Surround * Chrome Plated Back-plate * Low Carbon Top and Pole Piece * Triple Stacked Magnet Structure * Vented and Extended Pole Piece * Black Progressive Roll CONEX Spider * Woven Tinsel Leads * Gold-Plated Binding Posts * BAEISV Hybrid Voice Coil Former * C- Lock Rubber Gasket * Rubber Magnet Cover * Wood Packing Crate with Chrome Appointments * Priced per Speaker 4.25-5 cu should be good R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
LoudBlazer Posted March 20, 2009 Report Posted March 20, 2009 Get a can of resin if your worried and pour it into the corners and that might help cut down just enough to make it what you need. You dont need to lose a whole lot but I think you should be ok with what you have. Just cant put as much power on it. 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
aznboi3644 Posted March 20, 2009 Report Posted March 20, 2009 Get a can of resin if your worried and pour it into the corners and that might help cut down just enough to make it what you need. You dont need to lose a whole lot but I think you should be ok with what you have. Just cant put as much power on it. The cost for this would be retarded when some cheap 2x4s would take up more space for a lot less.
LoudBlazer Posted March 21, 2009 Report Posted March 21, 2009 $14 compared to buying cutting 2x4s then gluein them or screwing them int othe box. Then airflow and sound of 2x4s comapred to $14 mixing pouring drying and walla! Resin in the corners might even increase his output and bass. 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
tequila Posted March 21, 2009 Author Report Posted March 21, 2009 thanks for the great advice guys! ima look into the resin. '99 Civic hatch 18" AA Chaos - 7cuft @ 34hz - 114sq in. port Mac Audio Fearless ~ 1000wrms @ 2 Ohms Videos: Youtube
