So Plywood Is Bad
slugdub
Just wondering. Seems like people here would not approve of this as a material. Its what i've used in the past and it would mean starting from scratch to use another material (and gaining access to a woodshop, which isn't the end of the world.. but..)
Get some MDF, plywood isn't a good material for sub enclorsures, it breaks. Do you ever use google at all?
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Ive used Birch Plywood and work jus fine...
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
woah, harsh toke Brody! I searched here up and down for different materials. I guess I didn't try google :(
From my experience.. MDF chips and breaks easier than Plywood
2007 Chevy HHR LT
UNDER CONSTRUCTION
I'm not bashing you, it's just like you never do research. You can buy plywood that will work, but you would be better off just using MDF or possibly oak, birch also as Eric said. I have no experience with plywood but it's generally pretty weak. It's up to you you aren't running much power so use whatever you want.
Team T3 Audio
Team Sundown Audio
Team O.B.M
That is true, especially when going in with screws and such. Though Plywood doesn't hold up as well generally, to the poundings of bass as MDF. It just depends on what you get, Plywood wise.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Well I have a plywood box that someone else made. It seems to only require a few adjustements for my new speakers. I just had envisioned new ports, resealing them good, mounting new speakers, double checking the math and I'd be on my way.
Now I'm wondering if its not going to be that simple. I read the 12 volt.com guide, its long
Iv sean people use plywood and 2x4 bracing on walls. But they always seem to glass the inside of it just to make sure that it stays strong and air tight. Now weather its birch or not I dont know.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
  • Who's Online   0 Members, 0 Anonymous, 9432 Guests (See full list)
