DC Sound Lab
I have 2 12s lvl 4 wit a hifonics colossus amp but do you think my amp can push a third sub??? or should i just keep my system wit 2??
05 Ford F150- STOLEN!!!!4 AA Havocs 15s in a WALL4 Hifonics 2006ds1 kinetik 1800 in front4 kinetik 2400s n bakHifonics MaxxlinkAudiocontrol Epicenter2 runs 1/0 guage kicker hyperflexall other wires r knukonceptzTraded In05 Chevy SilveradoAscendant Audio 16 12s2 Mechman 320s1 Kinetik 1800 in front8 Kinetik 2400s n back4 2200 Audioques ampsLots of 0 gaugePioneer DeckAudio Control preampHifonics Maxxlink
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Audiocontrol Epicenter indash
All Rockford 1/0 & every cable in there
Jl audio xd 600/6
Rockford Fosgates Mids & highs
Built By Audiotistics!
depends on the ohm load of the amp and f you will have sufficent power and airspace for the third sub. you would have to run the amp bridged since it is a 2 channel amp. so you couldnt run a ohm load under 2
Edited by troy
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
well im kinda new to all this audio stuff!! my ?? is if my amp can push the 3 subs i know for sure it can push too easy but can it do da third one???
i saw this vid on youtube and it got me thinking??
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
being that its a dual monoblock, unless your ohm load is gonna be around 2ohms final then no on the 3rd sub imo
i believe it is gonna be 2 ohms final? friend is installin everythin so i really dont know how da whole ohm thing works!! wat would you recomend???
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
Do you know your coil setup? If so, go here:
http://www.the12volt.com/caraudio/woofer_configurations.asp
Select quantity 3 and your coil setup, then look at the diagrams to find what you're looking for.
Need an install? Hit me up.
[email protected]
they are d2
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
they are d2
with the dual 2 ohm subs you will either get a 1.34 or 3 ohm load, you could do it if you had a big monoblock amp that put out enough power at a 1 ohm load, but with the 2 channel amp i wouldnt recommend adding the 3rd sub.
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
thanks bro i need to get all this car audio stuff out of my head!! i still havent installed everything i have and i already want more!! this Sh*T is ADDICTING!!!!
NOW
2012 Dodge Ram Hemi
4 Havoc 12s
2 AQ 2200s
2 Kinetik 2400s
Pioneer Deck
Jl audio xd 600/6
  • Who's Online   0 Members, 0 Anonymous, 9437 Guests (See full list)
