I'm considering installing a 4ch. amp in my car for my cabin speakers, mainly for the built-in HPF. Here's something I came up with to power my MB Quart 35-80w fronts and Sony 45w rms/150w peak rears:
http://cgi.ebay.com/BOSS-CX350-400-WATT-4-...1713.m153.l1262
Good idea? Bad idea?
Where do you think I should mount an amp and how should I run wires? I have installed a sub with a bridged 2ch amp in my car so I am not unfamiliar with some stuff but something tells me this is a whole different ballgame...
I am open to any suggestions as to what amp to use, how to run what wires and where, and anything else I may need to know.
Thanks in advance,
Austin
EDIT- MB Quart model number is EKA 113; Sony number is XSGT6936A
Edited by ktownsdriftking
Too many projects, too little time...
stay away from cheaply made amps. cheap means bogus numbers, horrible efficiency, terrible sound quality, and a very short life span. how much are you looking to spend? and what do you have in the car now? gauge of wire ran to the sub, make and model of sub, amp powering sub, type of car etc?
Get a good 4channel amp....I would run deck power over that lol....just state your price range and ppl can help you.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
kenwood amps are pretty reasonable. they are in the 75-200 dollar range depending on how much power you want.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
I love my Sundown SAX-50.4. I am running a set of MB Quarts MB Quart RVF 210 and MB Quart RVF 164 and they scream. If you go into the Sundown section there is a pinned section where you can get them for 225 shipped. Highly recommended worth the price...
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
This is probably really unrealistic, but I don't want to spend more than $100 shipped. I don't need more power so much as I do the high-pass filter, hence the Boss amp with low RMS ratings. Like I said my 6x9s are only rated at 45w RMS each, and the Quarts don't have an RMS listed; just a 35-80w power range.
I an currently running an 8ga. Rockford Fosgate wiring kit and RCAs to a 2ch Sony 800w amp bridged to two Alpine type-S 10" dual-4 ohm subwoofers. I just acquired a 4 ga. Streetwires power and ground with a 100amp fuse holder from a friend who found it in a car he was dismantling. I am planning on upgrading the sub amp as well, to a Power Acoustik 560RMS sub amp. Could I run the 4ga. wire to the sub amp and run the 8ga. off of a distribution block to a 4ch.?
EDIT: the freebie wiring kit also came with two sets of Monster RCAs and a couple tiny runs of 8ga. power and ground. All of it was mounted on a slab of MDF, probably an old amp rack or something. I might reuse this for my amps or something, I'm not sure...
i will sell you my crunch 1400.4 for $100 shipped
P1400.4 4 x 175 @ 4-Ohms, 4 x 350 @ 2-Ohms, 2 x 700 @ 4-Ohms
----reference's----
meade916
I can't put 175w RMS to those speakers though!
The backs are rated to 40, that's probably conservative
The fronts are rated 30-80, again, probably conservative.
Thus, I only want a little bit of power.
...That MB Quart one intrigues me though, anyone use it before?
