4ch. Amp Ideas
white4d96
I'm considering installing a 4ch. amp in my car for my cabin speakers, mainly for the built-in HPF. Here's something I came up with to power my MB Quart 35-80w fronts and Sony 45w rms/150w peak rears:
http://cgi.ebay.com/BOSS-CX350-400-WATT-4-...1713.m153.l1262
Good idea? Bad idea?
Where do you think I should mount an amp and how should I run wires? I have installed a sub with a bridged 2ch amp in my car so I am not unfamiliar with some stuff but something tells me this is a whole different ballgame...
I am open to any suggestions as to what amp to use, how to run what wires and where, and anything else I may need to know.
Thanks in advance,
Austin
EDIT- MB Quart model number is EKA 113; Sony number is XSGT6936A
Edited by ktownsdriftking
Too many projects, too little time...
Get a good 4channel amp....I would run deck power over that lol....just state your price range and ppl can help you.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
kenwood amps are pretty reasonable. they are in the 75-200 dollar range depending on how much power you want.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
I love my Sundown SAX-50.4. I am running a set of MB Quarts MB Quart RVF 210 and MB Quart RVF 164 and they scream. If you go into the Sundown section there is a pinned section where you can get them for 225 shipped. Highly recommended worth the price...
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
This is probably really unrealistic, but I don't want to spend more than $100 shipped. I don't need more power so much as I do the high-pass filter, hence the Boss amp with low RMS ratings. Like I said my 6x9s are only rated at 45w RMS each, and the Quarts don't have an RMS listed; just a 35-80w power range.
I an currently running an 8ga. Rockford Fosgate wiring kit and RCAs to a 2ch Sony 800w amp bridged to two Alpine type-S 10" dual-4 ohm subwoofers. I just acquired a 4 ga. Streetwires power and ground with a 100amp fuse holder from a friend who found it in a car he was dismantling. I am planning on upgrading the sub amp as well, to a Power Acoustik 560RMS sub amp. Could I run the 4ga. wire to the sub amp and run the 8ga. off of a distribution block to a 4ch.?
EDIT: the freebie wiring kit also came with two sets of Monster RCAs and a couple tiny runs of 8ga. power and ground. All of it was mounted on a slab of MDF, probably an old amp rack or something. I might reuse this for my amps or something, I'm not sure...
I can't put 175w RMS to those speakers though!
The backs are rated to 40, that's probably conservative
The fronts are rated 30-80, again, probably conservative.
Thus, I only want a little bit of power.
...That MB Quart one intrigues me though, anyone use it before?
  • Who's Online   2 Members, 0 Anonymous, 1155 Guests (See full list)
