I would like to paint my sub box instead of carpeting it but i don't know what type of paint i should use or what a good brand is. I'm looking for something i could possibly pick up at home depot or lowes.
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
Depends on the wood. I like a good stain myself. My preferred application would be two coats of umbilical blood, but that shits expensive.
Can you imagine the raw spiritual power you'd be putting out from your box?
what the fuck?
umbilical blood? :search: wtf? are you painting over raw wood? if so you need to prime it first and then apply a sealer then a base coat and clear if you are going that far if you have any ?s pm me illl help you best i can
I use rustoleum textured paint it is avaible in a few different colors
When painting a box you will need to do a couple of things. You will want to fill in the screw holes and uneven wood holes, and sand down smooth. I use a primer on my boxes before i paint them just as an added step but I do not know if it is needed. I prefer to use the textured spray paint, it comes in a variety of colors and also helps out with the box moving around in trunk.
I thought i had more pictures of the paint process on this box. Oh well :unknw:
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
  • Who's Online   0 Members, 0 Anonymous, 2441 Guests (See full list)
