s-saudio is a wizard when it comes to box designs. plus, he had a pair of ID max 12's
----reference's----
meade916
Do as much airspace as you can with 2 4" aeroports.
From what I've seen with these subs they don't seem to need a lot of port area. Also if you tune real low they don't seem to play high very well but they're extremely nice 30-50hz :)
10.x volts fo' life!
Ok i found 1 but im not sure if the final length is for each port or total length for the 2 ports.. Meaning, it says 6.07... Is that 6.07 for each port or the length of both ports has to add up to 6.07"?
Use the Aeroport calculator .. http://rds.yahoo.com/_ylt=A0geu6I2Q9FJTWwB..._calculator.cgi
The port length is for each port . If you have a Flared kit , you go by the flared calculation .
To cut the straight ports to what you need take the flared length and minus it by 5" .
Each flared end including the ring is about 2.5" L .
Example ~ 4cuft , 32Hz tune , 3" diameter port , 2 ports = Flare Length Port required 8.11"
Cutt each straight port tube to 3.11" L . Assemble and thats it .
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
  • 5 weeks later...
just some pics of my box i built recently.. didnt port threw the back deck but im Very happy with the way it says except for some rattling.
Ports were painted nicely but i had trouble putting them back in after carpeting
1001bd mounted on the side. Wish the end caps woulda fitted too. thinking about grabbing another or a 501bd..
Edited by drew028
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
