I have a 2000 cavalier which you need one of those modules to keep factory chimes when you install a aftermarket headunit. Is it possible to just relocate the stock headunit to somewhere unseen and splice the power and ground (or new ground) for the new headunit? I have had some bad experiences with those modules and want to avoid them in my car completely. Any suggestions? If i install it like any other headunit will it harm my car or anything? I dont need the chimes.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
you do not need that modulke..
Done probably 80 of the cavi's.
done prob 300 chevy's at least with no module.
piece of cake man
piece of cake man
So just hardwire it and scrap the old stocker? All i lose are the chimes? Does anyone have a pigtail for a Alpine CDA9874?
Edited by fis10
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
i have used the module in an 01 cavalier...damn i didnt know u didnt need it ...ah well....i never had any problems with it tho...
Eclipse cd7000
you can buy a harness for a 00 chevy tracker and plug it it, everything works you just need to run your own Accessory power to the new HU
DC.jpgDC POWER
Wow i worked on it for hours today and couldnt get it to work. Where would i get the new accessory power from? Theres two Power inputs on the hu they are 12 volt ignition switched and 12 volt battery constant. Would i just connect those both together and get the new accessory power? I want the radio to shut off when i get out the car.
Edited by fis10
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
I have used the wipers before.
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
Do i connect the two Powers from the hu to the power source?
just acc to wiper fuse.
Subs: 4 Fi BL 18's
  • Who's Online   1 Member, 0 Anonymous, 3315 Guests (See full list)
